Flail Mower Flail mower rotor shaft stuck grass, how to solve this problem?
   / Flail mower rotor shaft stuck grass, how to solve this problem? #11
Wound up grass --- Learn to live with it. A flexible may help the issue. Otherwise a Lino knife, pliers and a narrow pry bar are friends
Wound up stuff on the seals can/will cause seal damage.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #12
To be clear, seppi and MeriCrusher are not the same company. Seppi is and Italian company, MeriCrusher is a Finnish brand name. The Manufacturer is Suokone. It's not possible to burn belts with a MeriCrusher . . . It is gear or chain driven. Most, but not all seppi machines are belt driven.
MeriCrusher would not be the best choice for mowing, the company is a below ground specialist. Seppi is a great manufacturer of flail mowers, and would be a good choice.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #13
Welcome to TBN CrushingMechanics. Where is Two Harbors? And, if you don't mind my asking, why do you like to torture mechanics?
   / Flail mower rotor shaft stuck grass, how to solve this problem? #14
As much as I detest PTO shaft safety covers, one might help here.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #15
Also, I notice that he has hammer blades mounted. Perhaps if he tried grass knives the results would be different. Hammers work great for small woody material as in orchard prunings or rough brush country but fail somewhat in use in grass.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #16
This made me go back and look - and realize I didn't read well. ROTOR shaft, not PTO shaft. I feel stupid....
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
TANK MANIFOLD (A55745)
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
