Flail Mower Flail mower rotor shaft stuck grass, how to solve this problem?
   / Flail mower rotor shaft stuck grass, how to solve this problem? #11
Wound up grass --- Learn to live with it. A flexible may help the issue. Otherwise a Lino knife, pliers and a narrow pry bar are friends
Wound up stuff on the seals can/will cause seal damage.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #12
To be clear, seppi and MeriCrusher are not the same company. Seppi is and Italian company, MeriCrusher is a Finnish brand name. The Manufacturer is Suokone. It's not possible to burn belts with a MeriCrusher . . . It is gear or chain driven. Most, but not all seppi machines are belt driven.
MeriCrusher would not be the best choice for mowing, the company is a below ground specialist. Seppi is a great manufacturer of flail mowers, and would be a good choice.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #13
Welcome to TBN CrushingMechanics. Where is Two Harbors? And, if you don't mind my asking, why do you like to torture mechanics?
   / Flail mower rotor shaft stuck grass, how to solve this problem? #14
As much as I detest PTO shaft safety covers, one might help here.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #15
Also, I notice that he has hammer blades mounted. Perhaps if he tried grass knives the results would be different. Hammers work great for small woody material as in orchard prunings or rough brush country but fail somewhat in use in grass.
   / Flail mower rotor shaft stuck grass, how to solve this problem? #16
This made me go back and look - and realize I didn't read well. ROTOR shaft, not PTO shaft. I feel stupid....
MILLERMATIC 251 W/LEADS (A55745)
MILLERMATIC 251...
2012 FORD F-750 SUPER DUTY (INOPERABLE) (A55745)
2012 FORD F-750...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2015 DRAGON 130 BBL VACUUM TRAILER (A55745)
2015 DRAGON 130...
2006 VOLVO VNL (A55745)
2006 VOLVO VNL...
