Electric Cars: Chev Bolt seems to be the first practical one.
Status
Not open for further replies.
   / Electric Cars: Chev Bolt seems to be the first practical one. #441
I don't think that's accurate.
At times, depending on driving mode, clutches engage and the gas motor directly turns one of the electric motors, in essence, direct drive with battery assist.
Here's a pretty good video that shows how it works...
That video is confusing. When the show the cartoon of the ICE linked to both electrics, they label that as "highly contentious". WTF does that mean???
   / Electric Cars: Chev Bolt seems to be the first practical one. #442
I think you just described the Chevy Volt. The only difference is that the main propulsion battery can also be charged by plugging in to either 110v or 220v. The ICE on a Volt is literally a generator and not linked to the drivetrain at all except electrically.
Again did not describe properly; should have read as various recharge options.
   / Electric Cars: Chev Bolt seems to be the first practical one. #444
Can they be mounted inboard similar to a differential with drive axles out to the wheels, to keep down unsprung weight? That much weight, that low, should be good for stability.
The inboard/drive shaft does increase weight and complexity but does provide an overall inprovement . Surprising how inboard mounted brakes and subject axles to such high windup torsion loads.
   / Electric Cars: Chev Bolt seems to be the first practical one. #445
agreed. Volt is gas electric car. Different from a locomotive though because gas engine is not coupled to motors directly, it only charges batteries, motors only pull power from batteries, never from ice generator directly. If you like volt and are looking for a better volt, used car, look at the Cadillac version, now cancelled but a much higher quality car, and a real head turner.
it only charges batteries, motors ONLY pull power from batteries, never from ice generator directly.
If talking about the 1st gen Volt
Actually (IN SOME CIRCUMSTANCES) the Volt does combine some ICE power (crankshaft rotational mechanical power) with the motor or the generator to drive the wheels.
It cannot drive the wheels using Only the gas engine directly, But based on
decisions the car makes as to what will drive the wheels most efficiently.
Whoops .. should have read All of the posts before responding,- Island tractor beat me to it.
this vid is interesting in explaining how the volts drivetrain does what it does.
Chevrolet Volt 4ET5 Transaxle Components and Operation - YouTube
Short version from GM in 2010?
Chevrolet Volt Drive Simulation - YouTube
And to further compiicate things , the Voltec 2
GM's Second Generation Voltec Drivetrain Explained (Voltec 2) - YouTube
   / Electric Cars: Chev Bolt seems to be the first practical one. #446
It means people who are taking things literally cannot call the VOLT and electric car because the gas engine is sometimes directly coupled to the drive wheels.
   / Electric Cars: Chev Bolt seems to be the first practical one. #447
I think you are mistaken.... at times, the Volt's gas engine IS directly coupled to the the wheels through the electric motor(s).
   / Electric Cars: Chev Bolt seems to be the first practical one. #448
   / Electric Cars: Chev Bolt seems to be the first practical one. #449
And the best quote from that article.....
"And, in the end, the average person likely won't care how the car does what it does, just that it does what they want it to do."
   / Electric Cars: Chev Bolt seems to be the first practical one. #450
Agree. It also seems like the Volt doesn't spend much time with the ICE engaged to the drivetrain and that when it does it is always in conjunction with the smaller electric motor. I can see, even after reading that GM engineer's explanation, why folks, including me, find it a challenge to understand just how the thing works.
Status
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
Eagle Weathervane (A55853)
Eagle Weathervane...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
Toyota 7FGU35 8,000lb. Propane Forklift (A55973)
Toyota 7FGU35...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
