Black Fly and Mosquito control (Canada)
   / Black Fly and Mosquito control (Canada) #1
BLSXJ
Gold Member
Pembroke, Ontario
Kubota L3400
What do you do or use to control the "bugs" on your property?
I've got a bit of wetland around the house, and the bugs are just insane! It was a nice day yesterday, but because of the bugs, we stayed in the house.
Bug spray helps, but its not enough.
   / Black Fly and Mosquito control (Canada) #2
Well the number one thing to do is to eliminate their habitat, essentially by reducing places that have standing water.
Cutting dead trees down or trimming some branches to let in more sunlight also helps as said sunlight also dries up the earth below it.
Now strictly talking about bug control, I personally have a mosquito magnet type of propane lure which burns propane and mimics human breath and sucks them in once they are too close.
Does it work? Yes. But in my personal case it is hard to place it in such a way as to lure all of them and away from you.
I have a couple of friends who have them and need to empty their bags on a weekly basis while in my case I seem to only need to empty it out once every 2 weeks to a month.
How much does it kill? I'd say a couple of thousand mosquitoes but I would keep mine even if it kills 500 since I rather have 500 less than on me.
As far as I know the mosquito magnet doesn't work on black flies, however there was another brand that has a. Big sticky paper panel where flies stick on while most mosquitoes got sucked in
I also have two uv lights that shock the mosquitoes as they fly into it.
I have looked into making some mosquito traps with tires (you can look up how to make them online) but never really got my hands around to making any (essentially creating standing water that you "filter" and keep the eggs from hatching and reducing their population. As far as I know it has to be filtered almost daily and for a big size lot it would take half a dozen over a couple of weeks to reduce their population.
Lastly, if you have a pond or a big standing puddle then you can buy pellets or "doughnuts" of a special kind of bacteria that eats the mosquito larvae. I have used these in the past with success on a drainage ditch that always stayed half full during summer.
P.s. even with said techniques you are looking at reducing their population and not eliminating them completely, but it will make bug spray more effective.
If you want to eliminate them then you can buy some insecticide and spray it on the house or fog it over the whole lot. As far as I remember permethrin is legal in canada and not that harmful to the environment. But after 1 to 2 rains the effect is almost gone. If you get a good dry season where nothing will wash it off then it can last a good month or two.
I know when I sprayed my lot for a party I had absolutely nothing flying or crawling in my yard for a week before it rained, then they started returning slowly.
Hope this helps, thankfully I don't have black flies in my neck of the woods.
   / Black Fly and Mosquito control (Canada) #3
I live near the swamp. With the warmth and water surrounding me the mosquitoes and bugs are thick down here. I spray Bifenthrin XTS once every three weeks. The stuff is cheap at approximately $1 per ounce. I mix 1.5 ounce/5 gallon and use about 2 gallon each time around my house. Stay away from pond and your garden. Without it, I will not be able to stay outside.
   / Black Fly and Mosquito control (Canada) #4
You've got no idea what bugs are like until you get way up north where they are. I grew up in the South but spent two summers in the Alaskan bush so I do know. Personally I don't think I'd live up there. You either freeze in winter or the bugs'll eat you alive in the summer. If it ain't the skeeters, it's the deer flies and the white socks and or the no seeums and sometimes all of em together. There's more bitin & flyin critters up there than I ever saw in any jungle on earth.
   / Black Fly and Mosquito control (Canada) #5
I use plenty of foul language but don't think it does much good. I was doing a horrible, almost impossible hydraulic repair day before yesterday, and the black flies took every possible advantage.
   / Black Fly and Mosquito control (Canada) #6
I must have been lucky in the years I worked in Michigan and Canada. After I spray after each swarm down here, every now and then I collect enough carcass of bugs/skeeters/yellow flies in my shopvac to mulch my flower bed. If it's worse than that up there, y'all can have it.
   / Black Fly and Mosquito control (Canada) #7
High deet bug spray and bug zappers are what I use in Ohio, last few years the winter has been mild here so the bugs haven't been killed off like they normally do.
I have a small bug zapper in the barn on a timer, it burns for a few hours a day to kill all the bugs I let in while working in there.
For the most part my ground is dry so bugs aren't as bad but I lived in the hocking hills which is deep wooded swampy land, there's no way to kill them all down there, I could only make my porch bearable.
Horse flys need traps, those things are crazy aggressive, there was a 60ft wide 3ft deep creek running threw the property, any time someone goes for a swim or fish they were violently attacked. I tried an old trick of hanging gallon bags of water around the area with pennies in them. It helped but wasn't a permanent solution.
   / Black Fly and Mosquito control (Canada) #8
For mosquitoes, I like to burn those coils. I often have one or two going on the workbench, with the big door open and it seems to keep them away. Some people may not like the smell but I don't find it offensive.
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A52377)
2022 Power Screen...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
