BX 22 - Three point won't lift
   / BX 22 - Three point won't lift #1
search4one
Member
Red Bluff, CA
Yanmar F395D Branson 4720I
Have a elderly friend that is not computer savy with a Kubota BX 22 and his three point won't lift. Recently purchased it and said the three point went up when the PO was showing him the tractor. He says he turned the knob under the seat both ways and didn't solve the problem. I'm thinking it might be something simple and hoping for ideas before i drive the 150 miles each way to go and see if I can get it working for him. Thanks
Randy Baker
Red Bluff, CA
   / BX 22 - Three point won't lift #2
Does this model have a backhoe? I'm not sure, but might be a valve to shut off the 3ph when backhoe is in use.
Knob is probably the mower height knob. Has no effect on 3ph. 3ph is independent of that.
Check oil? Especially if loader is raised, low oil might keep 3ph from working.
RPM. At idle, my 3ph doesn't work. Go to 1500RPM and it should work if rpm is the issue.
Good luck,
Ron
Good luck,
Ron
Thank you for your reply Ron,
It does not have a backhoe, don't know if it ever did. I haven't actually ever seen this tractor, he hasn't had it very long.. If I remember correctly he said he checked the oil level. I will have him try the RPM's you suggest and look for a shut off knob.
Randy baker
Red Bluff, CA
   / BX 22 - Three point won't lift #4
If it's a BX22, it originally came with a backhoe from the factory... it was the backhoe version of the BX2200. There should be a pair of hydraulic lines or couplers at the back of the tractor, above the PTO, for the backhoe. When the backhoe is removed, one of the lines going to the backhoe is supposed to be "jumpered" back into the other coupler on the back of the tractor. If you don't do this, the 3 point lift will not work. Here's a video of doing that on a BX22:
Kubota BX backhoe removal and storage - YouTube
You can see the jumper connection at about 49 sec. into the video.
   / BX 22 - Three point won't lift #5
This needs to be checked before the motor is started again. If you run it very long without those lines connected together, you can mess up the hydraulic pump.
Aaron Z
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
Year: 2017 Make: International Model: DuraStar 4300 Vehicle Type: Truck Mileage: 45,026 Plate: Body (A51692)
Year: 2017 Make...
