Urgent hydraulic purchase needed. Replacement cylinder
   / Urgent hydraulic purchase needed. Replacement cylinder
Surplus Center has a similar cyl for $129. It has a clevis base, a swivel eye rod end, a 1.5" rod, 30" collapsed length 15 " stroke.
3.25x15x1.5 DA HYD CYL | Double Acting Hydraulic Cylinders | Hydraulic Cylinders | Hydraulics | www.surpluscenter.com
That, or something similar might be the ticket. It would be worth buying 2 and removing the other to have equal cylinders. However, the stroke length is important in this case in that it drops the blade AND empties the bucket.
But you have made me think. It might be faster to simply buy 2 new ones if the specs are adequate.
Thanks
   / Urgent hydraulic purchase needed. Replacement cylinder #12
Thanks
Look through their site, they have a good selection of cylinders and stroke limiters :D
Aaron Z
   / Urgent hydraulic purchase needed. Replacement cylinder #13
3.5" bore
24" stroke
1.5" rod
I'm not exactly sure of the collapsed length.
Swivel eye on one side and clevis on the other. (This is the issue I am running into for a replacement. They seem to be built only with the same on both sides.)
Dalton Hydraulic - There are 6 units that meet the Bore / Stroke / Rod spec - none have the Clevis / Swivel combo you need.
Bailey Hydraulics was also another great suggestion.
My suggestion (and I'm not a Hydraulic guy either) would be
1) Call Bailey and/or Dalton and give them your exact needs and see what they say. If they can't get you an exact match then
2) Buy a new cylinder close to your needs as you can & have a local welding shop move the swivel end from the old cylinder to the new one.
As has been said before the words Fast & Cheap are usually only connected by the word Not.
Down Time sucks, I wish you the best of luck.
   / Urgent hydraulic purchase needed. Replacement cylinder #14
   / Urgent hydraulic purchase needed. Replacement cylinder #17
You are not far from Cincinnati. Hook Industrial Services does a lot cylinder repair. They are based out of Ft Wayne but they have a site in Cinci and a couple of others. They are reasonable and have lots of components on hand.
   / Urgent hydraulic purchase needed. Replacement cylinder #18
Definitely find a different shop. I have a shop in North GA with 2 mobile mechanics. For a cylinder like that you would expect $200 labor and roughly $35 in seals, but this is GA not KY.
   / Urgent hydraulic purchase needed. Replacement cylinder #19
The first thing I would do is write off the shop that gave me a $700 price for rebuilding a cylinder...as that is a lot if it isn't a specialty item. That is a price I would expect to see from a JD dealership, complete with the "golden" green paint! Like most of the others posting, I have a local shop that does my cylinders when I need them, and turn around time is usually 2 to 3 days, although I have had them done in a single day while I waited. The steer cylinders on my JD 2555 were $40 and the guy came to my house for the second one rather than me taking it off the tractor. (It amazed me that he remembered the seal size from the previous one six months earlier)
I got a price for repairing everyone of the cylinders on a detachable backhoe and all the rods needed replacing, and one is a special cylinder with a rack gear on it, and that was only $2000 for the complete job!
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A51692)
2018 Chevrolet...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51692)
Heil V-1722 28Yd...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
