2615 Tie rod ends
   / 2615 Tie rod ends #1
Dside
Wny
Mahindra 2615
I have a 2007 Mahindra 2615 with 725hrs, I noticed the right front tie rod is going bad, any cross reference available for tie rod ends? Thanks you...
   / 2615 Tie rod ends #2
Tie rods ends are fairly standard- the taper is near universal so all you need is the thread type on the rod/rack end. I'd remove it and bring it into the auto parts store. They should be able to get you there.
To realign- lift both front tires and put a line on each tire. Measure distance when both lines face forward and again when both lines face rearward.
About 1/8" toe in will help with steering when you get the machine above about 40 mph.
   / 2615 Tie rod ends
Thank you,I'll give it a try.
   / 2615 Tie rod ends #4
A tractor going 40 MPH would be somewhat unusual wouldn't it? I wouldn't want to be on mine going that fast.
   / 2615 Tie rod ends #5
Yes that's sarcasm- just getting toe close is all that's needed on a tractor. That's why the tape measure and line on the tires is all you need.
   / 2615 Tie rod ends
I knew RNeumann was joking around. BTW, A 2615 couldn't go 40 mph with a sail in a windstorm.
Garbage Truck (A51692)
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A52472)
2021 ALLMAND BROS...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
