BX2230 PTO not working
   / BX2230 PTO not working
Just a few pictures to show the broke shaft I wonder what he hit!
   / BX2230 PTO not working #12
I finally got some time off of work to work on the little tractor, got the transmission out and cleaned up and Dad came up for a visit at 76 years young he still likes working in the shop so we tore into the transmission and found three gears with bad teeth and a broken shaft, four bearing with some rough spots while rolling them so I ordered the parts to put it back together and now I am waiting on the time and parts.
Good Grief ! One has to suspect that the one who sold this machine knew it had major PTO issues and unloaded it. Hopefully you did not pay high dollar (and thankfully your Dad was around.) I'm 3 years behind him age wise and would never have had the nerve to pull that unit apart like you did.
my Dad and I both like to work in the shop but he feels better with someone with him rather than out there by himself. yep the guy new it had PTO trouble and told me so I bought it at a good price but was hoping I was going to get lucky on the repairs, like I said it is a project and it seams everything else is demanding my time.
some times I read where people don't follow up and report on a project so let me put some more information out about my little project. My dad and I got the transmission back together and a few days after he went home I was able to put the transmission back in the tractor, got it all back together and it works great. Took it over and cut my father-in-laws grass to help him and check the mower out. decided it needed a new belt it already had new blades, so I ordered a new belt and two new ball joints for the front end. when I removed the belt it worn out I believe it could have been the original one. Replaced the belt, the ball joints and both front tires so basically I started at the back and worked my way out the front and I believe my little project mower turned out to be a success. :thumbsup:
   / BX2230 PTO not working #15
I had the same shaft to break on my b.s. 2230 . The pto shafts turn free until I put the front cover on and now everything is real tight . I have to use channel locks to move them is there something I am missing. The front cover went on easy and there was no binding . Should the pto shafts be that tight.
   / BX2230 PTO not working #16
No ! Maybe there is a gasket or spacer missing causing the cover to tighten against a moving part ? I can't picture it, but is the cooling fan driven off that cover somehow? Strange. A new installation might be a LITTLE bit tighter but not to the point of being unable to turn the PTO with your hands. Plenty of lube in there ? Sure the PTO was out of gear when you tried to turn it ? I guess I'd take the chance and run it awhile and then try again and see if things are freed up.
I am thinking JWR is right, I just went out and checked mine to be sure and if you have it out of gear it should spin free.
   / BX2230 PTO not working #18
Checked everything out and found out the front Transmission cover is warped causing the clutch shaft bearing to lock up when you tighten the bolt. I found a used front transmission cover cheaper than a $900.00 new one. Will be here tomorrow and I will start putting it back together.
Glad you figured it out had me scratching my head. do you know how your shaft got broken?
   / BX2230 PTO not working #20
Yes, me too. Glad you got to the bottom of it. I figured it had to be something like that because the PTO (normally) turns freely when out of gear. Have to be cautious about the gasket surface, etc. so I guess straightening the old one was not feasible.
BESTWAY AG VSK35 LOT IDENTIFIER 29 (A53084)
BESTWAY AG VSK35...
2021 Chevrolet Corvette Stingray C8 Convertible (A51694)
2021 Chevrolet...
2006 Ford Explorer 4x4 SUV (A51694)
2006 Ford Explorer...
2023 JOHN DEERE 8R310 LOT IDENTIFIER 131 (A53084)
2023 JOHN DEERE...
JOHN DEERE Z997R LOT IDENTIFIER 82 (A53084)
JOHN DEERE Z997R...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2018 INTERNATIONAL...
