LED bulbs
/ LED bulbs #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I bought these at Costco...like their output and color. I put one in a garage door opener. Worked fine for several days, then problems. Hit or miss if it works. I thought because of vibration led would be better to use there than a filament bulb. Anyone else experience t his?
/ LED bulbs #2
I have cfl bulbs in my garage door openers for about 6 years no problems yet. Haven't gone the led route, bulbs seem over priced. I mean it's just a light bulb, when the prices go down I'll consider them.
/ LED bulbs #3
I have LED, in all of the high usage areas of the house, and like them. I chose the Cree brand for it cleanliness of RFI emissions. Not all LEDs are Radio Frequency clean.
BUT in the garage door opener, I worried about vibration of all the "guts" of the power supply components inside the LED's and the fact that the garage door opener is only on for a minute or two at the most a couple of times a day, you will never recover your cost over a simple incandescent light bulb. The same reason I don't have LED's in the closets, I will never live long enough to recover their costs.
/ LED bulbs #4
We have a LiftMaster Model 3280M garage door opener that was installed on 11/21/2012. The manual says to only use incandescent bulbs of 100 watt or less. But somewhere I read that LED bulbs might or might not work. Since I've replaced most of our light bulbs inside and out of the house, I tried LED bulbs in the garage door opener; nothing, would not work at all. The only other complaint I have had with LED bulbs is that we have 4 lamps with 3-way bulbs. Three of those lamps are rarely used. But one is usually on about 16 hours a day, always on the brightest setting, and that bulb won't last a year before I have to replace it.
/ LED bulbs #5
I have only installed a few led bulbs as the incandescent or florescent bulbs failed. My garage door opener has only needed the incandescent bulbs replaced once in 24 years. If a cheap incandescent replacement is still available when they go I will replace with those.
A little off topic but relevant to LEDs and vibration. I replaced the headlight bulb in my motorcycle with an LED. You can't get much more vibration and it continues to work fine. However, the LED replacement bulb does not have the same beam pattern and there is very little difference between the high and low settings. I ended up just aiming the low beam down so it won't blind people and left it in as it's much brighter and makes me more visible even in the daytime.
/ LED bulbs #6
I have LED in my openers without any issues. I believe they were the cheap Fiat brand from HD. It's been about a year.
/ LED bulbs #8
I use my 2 GDOs as "path lights" so that I don't have to switch on all of the 16 or so fluorescent fixtures just to navigate through the basement. I even added a LED 4ft shop light (Costco) on each one on about a 10ft extension cord with one of these
The combined length of the bulb and "adapter" was so long that I needed to leave the lamp cover off. No problem. Since I often leave these on for extended periods (overnight), I wanted the low power consumption of LED bulbs in the GDOs also. I think I used the cheapest available at Lowes (Utilitech).
This setup has worked perfectly for several years now. The GDOs are Liftmaster.
/ LED bulbs #9
Good topic.
I have been using LED bulbs for the past year in my 5 year old garage door opener (LiftMaster) without a problem. (Philips 14w, 100w equivalent from Home Depot)
A month ago, I had the sliding doors on my utility pole building replaced with two overhead doors and LiftMaster openers. The installers told me not to use LED bulbs because the LED bulbs could interfere with the door opener electronics. They also told me of customers calling them about erratic behavior of their openers. And after finding that they had installed LED bulbs, told them to change back to incandescent or florescent bulbs, the problems stopped.
So for now my new door openers have florescent bulbs in them but I am going to try the same Philips LED bulbs in them as I have in my basement garage door opener. The manuals that came with the openers do say to use incandescent or florescent bulbs, no mention of LEDs. :confused3:
/ LED bulbs
Actually be having a bit of issue of it opening right after shutting it....going to switch back.
/ LED bulbs #11
Good topic.
Keep in mind that all LED power supply's are not built the same. Some are serious emitters of RF energy, and some are not. I have had good luck with the Cree brand so far.
See my thread on the subject here:
http://www.tractorbynet.com/forums/related-topics/318587-rfi-cree-led-bulbs.html?highlight=bulb
/ LED bulbs #12
My porch lights get left on a lot, so have had CFLs in them for years. I choose the lowest wattage I can find, currently 25w equivalent. I think they actually use 6 watts. The next time one fails I'll replace it with an LED, but they last for years. I installed the current bulbs 14 years ago and they are still working fine.
I replaced the 65w bulbs in the kitchen can lights with LEDs a while back. It really saves on the air conditioning. :D
/ LED bulbs #13
That's what I tried in my garage door opener with no luck. And that what lasts less than a year in our 3 way lamp that's on about 16 hours a day. Home Depot replaced one under warranty, but this last time I bought "Great Value" cheaper at Walmart.
/ LED bulbs #14
My tenant called because the opener did not work and his wife was most unhappy...
Checked it out and found 2 LED bulbs which I did not install.
Removed the LED bulbs and it worked fine.
I like 130V rough service incandescent and installed same.
/ LED bulbs #15
A good example of what I was told by the contractor who installed my new garage doors just last month.
/ LED bulbs #16
Now, think about this garage door opener thing. They operate near 300Mhz. And if a source of RFI (Radio Frequency Interference) puts out enough trash from its switching type power supply, to affect a nearby 300Mhz receiver, wow, think about all of the other garbage all through the radio spectrum they are generating.
We as a society just keep on buying these cheap switch mode power supplies and putting them in everything. Our rules and regulations are wholly inadequate to protect the radio spectrum. It only takes a few cents per item to suppress this electronic pollution, but we won't spend this money to make them clean.
Think about the "antenna's" that these devices have to radiate their RF energy in the airwaves. Yes the house wiring, and entrance wiring for sure, and some may make it through the transformers to radiate over the longer powerlines. I haven't detected any RFI from Cree Led bulbs, but many others are horrible RF radiators. Most Chinese switch mode power supplies are filthy, some more than others.
The end result is over the last 10 years the "noise floor" has risen by several decibels. I predict that this will continue thru the years as an ever increasing pollution source.
We thought nothing about chemical pollution of our environment until some rivers caught fire and people got sick. And we are totally ignoring this new form of "pollution". The pollution of our RF spectrum. It makes our radio receivers "deaf" and decreases the ranges that communication can be maintained. It effects all radio services and is no respecter of boundaries.
But money talks, and BS walks. We will always buy the lowest cost item when we don't see a benefit to buying the higher priced one.
/ LED bulbs #17
Garage door openers (at least mine) requires a rough service bulb. Ir is a sears chain drive, and there is quite a bit of vibration. I have tried CFLs and LEDs and neither has lasted more than a month or two. Rough duty bulbs, 3-5 years.
Paul
/ LED bulbs #18
James, I think that one of the reasons that the rf spectrum pollution continues is that something like a river catching fire is readily noticeable to everyone, while the frequency problem would only be noticeable to those interested in the field. Remember back in the day of unshielded spark plug wires when few cars had radios? Once am radios started to become prevalent that pretty much forced the retirement of the dirty plug wires. Of course with tv coming through a cable, and most music being streamed or listened to on the fm band it might get considerably worse before anything is done.
As to the garage door openers being tough on light bulbs, how about having a cheap ceiling mount fixture (or two) and feed them from the power to the onboard socket?
/ LED bulbs #19
The price on LEDs is fast approaching that of CFLs. We just bought a new (to us) house. We have changed out over 90% of the lamps throughout. I installed a 12" X 48" LED panel light in my office and in the process of installing 8 new 2 lamp LED fixtures in the Garage. I have noted no RF interference with any thing yet. My hearing aid has a setting that only picks up the blue tooth loop at our church. When setting idol it picks up a lot of RF from CFLs and fans. Does not happen with the LEDs. Through sales, promotions, rebates, and etc; I have not paid more than $3 per lamp. The office panel and the garage composite units are comparable in price with CFL fixtures with their lamps. Leds are here to stay.
Ron
/ LED bulbs #20
" I chose the Cree brand for it cleanliness of RFI emissions. Not all LEDs are Radio Frequency clean."
Wish someone would have explained this to me before I bought four of the 4' fixtures from ebay. They mess up my radio something terrible in the shop. I have to hang it outside on a screw to get far enough away for it to work ok.
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
3098 (A63117)
3098 (A63117)
2022 EZ-GO ELITE...
2017 Toro GrandStand 52in Stand-On Mower (A64553)
2017 Toro...
