Where to get a seal that is "no longer available"
   / Where to get a seal that is "no longer available" #1
Jbullfrog
Avoca, IA
Ford / 1910
I'm working on a Ford 1910 tractor that ate the pto bearing and seal. Sourcing the oil seal is causing problems, as it is no longer available. it has P J 2304 o on it and a logo that looks like Amcs. I found a napa 15352 is the same size, but also not available. the bore measures 61.53mm, the shaft 39.93mm, and it's 12mm deep. The tractor was built in Japan in 1984.
   / Where to get a seal that is "no longer available" #2
61,5 x 40 x 12 ?
   / Where to get a seal that is "no longer available" #3
see if you have bearing specialty shop in your town and take it in . Im sure one can be matched
   / Where to get a seal that is "no longer available" #6
Like was said, most any bearing supply house should be able to provide a seal by dimensions only. Motion Industries is our local go-to place. You might be able to get in touch with them if a local business can't help you.:thumbsup:
   / Where to get a seal that is "no longer available" #7
When searching for a seal by size you will want the outside diameter to be slightly larger than the bore for a press fit. The inside needs to be smaller than the shaft diameter for a good seal. The depth or thickness can usually be off some one way or the other and still work okay.
A 62mm OD seal would give you a .018" press fit which should work since the rubber case has more give than a metal to metal press fit. You will need an ID of about 39mm. 38mm may be too tight but if the shaft has a groove worn in it you might get by with that. The depth cold probably 10 to 14 and be okay.
Converting millimeters to inches it looks like a Grainger number 35UC43 might work but it would only be .010" smaller inside than your shaft so it wouldn't have a great seal.
   / Where to get a seal that is "no longer available" #9
also try company called motion industry they are nationwide
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
2008 Chev Impala (A51694)
2008 Chev Impala...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
