Plastic gas cans for water
   / Plastic gas cans for water #1
DrRod
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
So we are gathering at the farm and my daughter's husband shows up with two big red plastic gas cans full of water. Brand new, never been used. But I have concerns. They make different plastics for different uses and I don't think the plastic for gas is the right thing for water. Anyone have some fact on this? Thanks so much.
   / Plastic gas cans for water #2
It may or may not be the same plastic as used for water cans. I would have concerns about drinking it. Water cans have to use food grade plastic.
   / Plastic gas cans for water #3
Look to see if there's a recycle symbol on the gas cans. I bet it's probably polyethylene. I believe that is fine (I think bottled water containers are made from it) but you should research it to be sure.
   / Plastic gas cans for water #4
5 gallon water jugs are blue plastic. Sometimes they are white or clear. Gasoline jugs are red,diesel or kerosene are yellow.
   / Plastic gas cans for water #5
I'm with you. Use it to water the flowers, but not for drinking. Even plastics approved to hold drinking water, are suspect in my opinion.
   / Plastic gas cans for water #6
AFAIK they're the same plastic, but I wouldn't take a chance either.
   / Plastic gas cans for water #7
Yep. HDPE. Same stuff that's used for drinking water. Perfectly safe, but why would anyone do that? There are water containers readily available.
   / Plastic gas cans for water #8
True and as Larry Caldwell stated in post #4, there are different coloured containers for various fluids... but that's mostly for quick reference/recognition. If the son-in-law was using the red containers for potable water, then all he needs to do is mark the top (in permanent marker/texta/'sharpie') POTABLE WATER. And wrap/paint the circumference of the container with a blue 'band'.
I do that here. All of my fuel canisters are red, but my DIESEL cans have a yellow band and my 2-STROKE can has a black band. That leaves plain red as PETROL.
   / Plastic gas cans for water #9
I am betting it was an availability or cost issue. Around here the red cans are common, blue not so much, and the blue ones cost a little more. I'd still try to find a blue can just because I need all the help I can get sorting out containers and all the different types of fuel I have, but in a pinch I could see using a clean red can that was well labeled.
   / Plastic gas cans for water #10
All of the cans/jugs designed/labeled specifically for kerosene that I have seen have been blue.
Steve
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
Misc. Dell Docking Stations and Keyboards (A50325)
Misc. Dell Docking...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
