2010 Kubota ZD326S-60
   / 2010 Kubota ZD326S-60
I'm between the ZG227 and the ZD1021, decisions decisions
Haha is it shaft drive like the ZG227? I see they retail for the same price.
   / 2010 Kubota ZD326S-60 #14
Sadly no, I recall that was one of your requirements. I went with speed, deck gauge and size, and ease of access to deck, belts, with the operator station rating high up on the list for comfort. And the KW engine, since I heard so many good things about them,
No plan for requirement...... the ZG227 and Z726 is only $1500 less than ZD1021...... so you guys think a 60" deck is to big for 1.5-2acres of mowing? Should I look at 54"?
   / 2010 Kubota ZD326S-60 #17
Man with 0% for 48, swing for the fences. Get the zd1211. I ran my buddies in lieu of a demo and will be ordering one today. Getting the rear discharge deck and they are as rare as a hens tooth here. Also, IIRC, the warrant isn't 4 years due to them being considered commercial mowers even if only used for personal use. You won't be unhappy with the larger, more powerful machine
Brett
   / 2010 Kubota ZD326S-60 #18
I have a 60 inch and I routinely go beyond 2 acres of mowing. Plus I have some areas in the yard that are tight and have obstacles. The mower deck however offered no choice in size to the engine it was matched with. So I did not have a choice. Sort of glad I did not.
But I did walk around and look at where I planned on going, parking and hauling measurements and what not.
Good luck!
What did you guys pay for yours?
   / 2010 Kubota ZD326S-60 #20
14k for a 60" rear discharge about 13.6 for side discharge was the quotes I got. Those were out the door but I'm not paying taxes
Brett
Deere 310L (A53317)
Deere 310L (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2005 Fleetwood Model D Camper, VIN # 5B4MPA7GX53402612 (A57453)
2005 Fleetwood...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
