The Tallest Heaviest Tree That I Have Put On The Burn Pile, 42', 18.5" DBH
   / The Tallest Heaviest Tree That I Have Put On The Burn Pile, 42', 18.5" DBH
I did call my neighbor and he said he wants the wood, will come cut it after he gets the hay cut and baled.
   / The Tallest Heaviest Tree That I Have Put On The Burn Pile, 42', 18.5" DBH #12
Ever consider loading the rear tires?
   / The Tallest Heaviest Tree That I Have Put On The Burn Pile, 42', 18.5" DBH #13
<snip> Now that's impressive! Glad I don't have a budget for something like that; there's no end to the havoc I could reek with one of those...:laughing:
After seeing your balancing act pics you may actually be more nutz than I am, and that's saying something!:cool:
So with the tree in the middle of the grapple it should weigh around 2,600 pounds. :thumbsup:
Is that all?!:shocked:
   / The Tallest Heaviest Tree That I Have Put On The Burn Pile, 42', 18.5" DBH #14
Wow, a 42' tree! That's not a burn pile, it's a forest fire!
No, it is designed with enough weight on the back, that orange casting weighs 2200 pounds.
I was trying to see if it would reach the tipping point when I extended the boom, it did!
Yep, I have been called that and worse! :D
Well it is probably heavier. I didn't have the boom as high when using the scale, as when it reached the tipping point .
As you can see from the Rated Load chart, it will hold more weight when the boom is higher:
Here it is with the boom fully retracted:
And 5,000 pounds on the scale:
Raised the boom a little more, scale shows OF for over flow. The rear wheels are still on the ground:
   / The Tallest Heaviest Tree That I Have Put On The Burn Pile, 42', 18.5" DBH #17
Fake news!:laughing:
How much is one of those scales? What is it called?
Thanks,
CM
Mine was just over $300 on eBay 4 years ago.
It is called a Crane Scale. Measures in 1 pound increments to 5,000 pounds.
DigiWeigh brand.
   / The Tallest Heaviest Tree That I Have Put On The Burn Pile, 42', 18.5" DBH #19
Thanks!
So, are you using the tree stump to anchor the scale? How do you have it anchored, screw eye?
Chain, it shows in these pictures.
Right click to open in new tab for a larger expandable picture.
2022 JOHN DEERE 317G SKID STEER (A51242)
2022 JOHN DEERE...
2012 CATERPILLAR 320EL EXCAVATOR (A51242)
2012 CATERPILLAR...
2016 Dodge Charger Sedan (A50324)
2016 Dodge Charger...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2013 NISSAN JUKE (A50324)
2013 NISSAN JUKE...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
