Priced a new Kubota L2501 with implements
   / Priced a new Kubota L2501 with implements #31
I own two other Kubota Diesels. And have operated many more. None of them had the nauseating smell of the L2501.
Do you own a L2501?
No but I can't even really smell diesel exhaust any more, I think I burned out those smell receptors. You upgraded and I am glad for you but there is a place for simple diesel tractors.
   / Priced a new Kubota L2501 with implements #32
Duplicate
   / Priced a new Kubota L2501 with implements #33
My L2501 does not have any diesel smell after started up for the first time of the day. something must have been wrong with the guy above tractor, that stunk so bad. It is a bit noisy, but not uncomfortably so. I think that is because the torque curve is up at higher rpm's than some of the large L models. It produces the peak power, for the pto, at around 2500 rpms. I have 70 acres and lots of trails to keep cut with about 15 acres of fields and it does everything I have required. I like not having the regen emission controls. I think that will be a very expensive thing if it has problems.
   / Priced a new Kubota L2501 with implements #34
Do you own a L2501?
I currently own a L2501, and I have not experienced what you describe........If I dont turn on the glow plugs long enough, it will puff black smoke that stinks when it starts. But that is only that one puff. As far as noise, it is not any louder then any other non emissions tractor that I have operated. In fact it is quieter then an old B series I used to have. Maybe just a different tone then the B because of the engine size.
I do have no doubt that any tractor with a DPF is a lot quieter. Those things are giant mufflers and since they filter out the soot, there is no oder either.
I bet once someone operates on of those it would be hard to go back! LOL!
I'm happy with my L2501.
Also glad your dealer worked with you on a tractor you were not happy with.
   / Priced a new Kubota L2501 with implements #35
My whole reason for getting the 2501 was because it is simple. I would love to have more HP, but to me the increased potential for a failure was not worth it. I just want to do normal fluid and filter changes, put fuel in it and work!
If it takes me longer to mow my field because I only have 25 HP.....so be it.
I'm sure they will get all this crap worked out in 10 years or so, and then I will upgrade, but for now I like having an "old" style tractor.
   / Priced a new Kubota L2501 with implements #36
Yeah I would prefer not to have the dpf. But I didn't like the L2501. Maybe I had a bad one. Exhaust seemed to fog all the time.
   / Priced a new Kubota L2501 with implements #37
Yes may have been an issue with mine. I have a L3830 which has no dpf obviously. It's an excellent machine, quiet and clean burning.
Glad you like your L2501. Wish mine had worked out.
   / Priced a new Kubota L2501 with implements #38
Not only is the 2501 simple, but it's a sleeper, with a much larger engine than you'd normally see in a 25HP tractor. This is really a 100 cubic inch 34HP engine that is just limited in RPM. It's got a ton of grunt at low RPM.
Kubota could have taken their 90 cubic inch 32HP engine and limited it, but instead they jumped up to the next size block for the L2501. Always thought that was interesting.
   / Priced a new Kubota L2501 with implements #39
... I don't have a need for remote valves presently....
Yes you do unless whatever you are going to be using the box blade on is perfectly flat, straight and smooth etc...using any grading etc. type attachment is much easier to use if you can adjust the implement from the seat...i.e., hydraulic Top and Tilt...
Being able to continually make minor adjustments to any grading implement while working is paramount for getting the full benefit of the tool...it (T&T) greatly mellows the learning curve...T&T can be the difference (with an inexperienced user) between making a mess and leaving a professionally done job...or close to it...
If you have any serious box blade or other grading work to do...go for the remotes and T&T...
Can I adjust the height and tilt of box blade manually without paying for hydraulic Top and Tilt? I asked this question to the dealer and he has no clue... he then asked why I want the Top and Tilt kit, that he has NEVER sold one.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
48in Ditch Witch Harley Rake Mini Skid (A56436)
48in Ditch Witch...
2020 DRAGON ESP...
2008 Komatsu WB146-5 (A55272)
2008 Komatsu...
Dump Truck Salt Spreader (A55272)
Dump Truck Salt...
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
