Wheel/Rim SIzes between JD & Yanmar
   / Wheel/Rim SIzes between JD & Yanmar #1
richriddle
Gold Member
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
In looking for Ag tires and rims/wheels for the YM276D, I noticed that the JD 870 has the same size front wheels/tires in the specifications (7 x 14). Coincidentally it also has the same size turf wheel/tire at 25x8.50-14. How can one determine if the JD 870 wheel has the same hole pattern and setback as the YM276D? The JD 870 front wheels are easily ordered. Thanks.
   / Wheel/Rim SIzes between JD & Yanmar #2
I don't know the answer to that. Is the 870 wheel the same as the 850 wheel? What about the 950/970?
There is a good chance of an interchange being possible somewhere along the ling because many of those tractors used the same Yanmar axle configuration.
I do know that the YM336D and the JD 1050 used the same wheels because I measured and then mounted a used set of JD wheels & tires during my own tire search. In fact, I ultimately ended up using JD1050 wheels on our YM336D.
rScotty
   / Wheel/Rim SIzes between JD & Yanmar #3
I put a John Deere rear rim on my 276D.
Part # CH10975 (9x24) (Use with 11.2x24 tire)
Looks like it fits JD 850, 950, and 1050
I'm looking at the original paperwork that I got with the rim.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2009 Ford Crown Victoria Sedan (A56859)
2009 Ford Crown...
Black Warrior Apache Smoker (A57453)
Black Warrior...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
500BBL WHEELED...
13042tx (A55973)
13042tx (A55973)
