Mahindra 2538 seat upgrade
   / Mahindra 2538 seat upgrade #11
I thought you had to be in the seat to start it in addition to pressing the clutch. If not, good to know. I may give the Michigan seat a try.
   / Mahindra 2538 seat upgrade #12
The 2538 doesnt have a clutch just a brake on the left side to push in to start. I have been beside the tractor and mashed the brake with my hand to start it before, been a few times I needed to move the 3 point a little to hook up a bush hog but had already cut it off.
   / Mahindra 2538 seat upgrade #13
My 3016 has no seat safety switch. Never did. It did come with a clutch switch and a pto switch. I'm considering making the clutch switch disappear.
   / Mahindra 2538 seat upgrade #14
My 4035 has no safety switches. I start it from the ground all the time. There may be a safety on the HST or PTO so it won't start if something is engaged, but I have never pressed the HST go-pedal or turned on the PTO while trying to start, so I don't know for sure.
   / Mahindra 2538 seat upgrade #15
That's the same seat I have on my 4025. Very nice.
   / Mahindra 2538 seat upgrade #16
I read a couple places where people got the seat from 2540 and put in on there, seemed to be a big upgrade. I cant find the thread right now but I believe its a suspension seat.
I have a 2540. The seat will indeed absorb gross indignities. Of course, being vinyl, you'll be sitting in a puddle of sweat unless you put a cover on it.
   / Mahindra 2538 seat upgrade #17
If it is like the seat I linked above, no puddles as it is built with a drain hole. Ya still sweat profusely, but the boys aren't floating in it...
   / Mahindra 2538 seat upgrade #18
You are technically correct, of course. Still, gonna get me a sheepskin ...
Ordered the v5300 and bolted it on and man did that do the trick. My back thanks you guys for the suggestion.
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
PALLET OF FUSION EQUIPMENT (A50854)
PALLET OF FUSION...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
