How not to remove a rock with your skidsteer...
   / How not to remove a rock with your skidsteer... #2
Another "genius" on a skid steer!!
AND another example of why I got rid on my skid steer and bought a tractor/pallet forks with a grapple!!
SR
   / How not to remove a rock with your skidsteer... #3
Wow, just wow. For Sale: lightly used skid steer, minor scratches on the right side.....
   / How not to remove a rock with your skidsteer... #4
SR
That guy sucks at operating and this isn't a fair testament against skid steers. He'd have probably bent loader cylinders had he had a tractor.
   / How not to remove a rock with your skidsteer... #5
Agree! He wasn't smooth at all.
   / How not to remove a rock with your skidsteer... #6
Obviously a rental. No one that owned one would treat it in that manner. Why rental machines are in such bad shape.
   / How not to remove a rock with your skidsteer... #7
I'm impressed with those forks!
   / How not to remove a rock with your skidsteer... #8
Sliding the forks together a bit would have helped .
   / How not to remove a rock with your skidsteer... #9
BINGO! We have a winner! I ALWAYS slide my forks together when dealing with rocks, in fact I can slide them together, shove them into the ground GRAPPLE the rock, and pull it right out of the ground!
You just can't beat the versatility of pallet forks with a matching grapple!
The skid steer I had, would NEVER have the traction to do that and would have a huge spot in my hay field tore up "trying" to get it done!
SR
   / How not to remove a rock with your skidsteer... #10
:rolleyes: Hope it was rental and the operator got charge extra.
   / How not to remove a rock with your skidsteer... #11
This is why I will never buy a rental unit when they rotate older ones out
   / How not to remove a rock with your skidsteer... #12
Unless that film is speed up he isn't too bad at the controls. Honestly pretty quick. He almost got that rock out.... forks together would have likely helped but really he just fell into his own hole. Still major fail and a little more caution and attention would have kept that from happening but not the worst fail ever.
   / How not to remove a rock with your skidsteer... #13
I'd like to work as an operator with you my supervisor.
   / How not to remove a rock with your skidsteer... #16
That's a new one.
He made it look easy.
That's the perfect storm right there.
1. Hitting limit of raised bucket (i.e. transferring momentum & amplifying torque), while
2. Stopping while going backwards (transferring more momentum), while
3. On a slight incline (requiring less roll to reach pivot point)
   / How not to remove a rock with your skidsteer... #17
I really only ment that the operator in that video had used some machines before not that moving at loader that quickly was helping him or safe, its just that most noobs with a rental machine can barely move the sticks the correct way on the first try.
And you do realize those older smaller bobcats tip over really easily, newer larger ones are a little better but not much.. If you spend an hour watching youtube fails of these things you will learn that this guys fail wasn't to serious and much closer to an avoidable accident compared to total noob failure. Also pro operators fail sometimes too.
   / How not to remove a rock with your skidsteer... #18
This is just my opinion but if you think he was an ok operator then you need to watch an expert sometime. The operator was very rough and had no clue as to the physics involved. If he would have got the tines under the rock right away the upset would have never happened.
Also he spent far to much time prancing around on the back wheels. Four tires on the ground give far more stability and believe it or not twice as much traction. This was a totally preventable upset.
   / How not to remove a rock with your skidsteer... #19
That's a new one.
Surely he mean to do that. No one is that stupid... right? :D
   / How not to remove a rock with your skidsteer... #20
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2426 (A60432)
2426 (A60432)
7038CFL (A59228)
7038CFL (A59228)
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
