Sorry guys if i wasn't being clear. Good battery, it will crank but not start, i've traced it down to fuel problem, I think. Good fuel, no interruption in lines, good fuel to pump.
Was doing some road grading with box blade and it just died, checked lines and restarted with ether. Got home now wont start at all even with ether.
Had someone check it out and they suggested to rebuild pump, fuel is being pumped but it doesn't seem like enough. I was just checking if you guys could help. How much fuel should the injectors be feeding? A strong stream? Short bursts?
Because mine is small short bursts coming out of injectors. Doesn't seem like enough??
Or is there something else that would make it seem like it's not getting fuel?
