Gator 6x4 dip stick tube snapped
   / Gator 6x4 dip stick tube snapped #1
weavertg14543
Member
rush,ny
john Deere gator 6x4 ferris pro cut s 61 inch 67 cub cadet Kubota ls3130
So went to check the oil level on my gator over the weekend and the tube for the dio stick snapped off flush at the engine. Has any one else done this? Maybe inshould stop working out? Ordered a new one but not sure how it goes in. Does anyone have a parts diagram showing this?
   / Gator 6x4 dip stick tube snapped #2
Can't help with the attachment, but did they just use a cheap-o pot metal for the tube?
   / Gator 6x4 dip stick tube snapped #3
Schematic on jdparts
John Deere - Parts Catalog
Found this for the tube.. looks like there is a bracket to bolt it on, and an 0-ring to seal it. Your new part should give you a good clue to how it goes on.
   / Gator 6x4 dip stick tube snapped #4
Kawasaki? They normally just push into the engine with an o-ring. You'll have to dig the old piece out.
   / Gator 6x4 dip stick tube snapped #5
Is the engine diesel or petrol?
It's a gas engine
   / Gator 6x4 dip stick tube snapped #7
No it just snapped at the base I'll take a pic when I get home
   / Gator 6x4 dip stick tube snapped #9
Had a dip stick tube break off on a car engine before. Took a welding rod put a little hook on the one end, wrapped it around a screwdriver on the other. Fed it down the tube till it hooked the bottom, used both hands on the screwdriver, pulled up sharply. Came out the first try.
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
