JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,719
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
I thought we had finished this discussion but I will reply again.I only said that if the rear discharge mower decks made the under side of the frame (inside the rails), more difficult to clean than my side discharge, I would not want one. The problem really is the low fuel tank and especially the steel bracket for it on the left side and the low battery and tray on the right. In my environment the dirt and debris sticks all over the driveshaft and u-joints and the inner frame rails. It seems to me that the dirt all over the u-joints would not be beneficial. When I really clean this area I spray with a de greaser, let it set for a while and then hose off. I wait at least one day for the joints to dry good before greasing them again. I will say again there is no type blower that will remove this gunk. I have both gas and electric. There isn't enough room to get a blower wand in the area unless you have a rack to get the tractor up a couple of feet. I have to use a flex hose on one my grease gun as I cannot even get my straight tubed grease gun to two of the nipples. You can get to one from the side. I'm sure you could blow off dry or even damp grass but that isn't the problem I am describing. My concern is that the rear discharge might make my situation worse. When I do clean the area described I look like I have been greased and then de greased or maybe the other way around. Do any of you Guys have fire ants? I could get rid of mine but none of my neighbors worry about them and just keep mowing them down and they spread back to my property.
You have a side discharge so your probably not going to add an additional rear discharge deck anyway.
Those of us that have had BOTH and have Fs have expressed our satisfaction and actual hands on experience and ownership with our rear discharge decks on our F machines after many years of use. No experience vs experienced. Sure those that have not bought yet will weigh the options and make their choice.
I to am bless and know Sigarms is also. Just don't get a rear discharge mowing deck and be happy with what you already have while giving thanks.
Now, what was the original question?
