Need more help with my ym2000. (Over heating)
   / Need more help with my ym2000. (Over heating) #1
dirtracer7x
Fayetteville, AR
Ym2000
So I finally got the finish mower hooked up and started mowing. 1 in pto, 2nd gear high in trans @ 2000rpm. Plenty of power but didn't take but 5 mins for it to start puking water. Pulled over to hose and sprayed through radiator and cooled it down a bit. Popped cap and added some water. After filling it again it looks like there is barely any flow. On a car you can really see the water moving after thermostat opens.
   / Need more help with my ym2000. (Over heating) #2
I don't think you have a thermostat. Never owned a 2000 but I know my old 2002D had a strong flow. I would think the 2000 should.
   / Need more help with my ym2000. (Over heating) #3
Flow or no flow,it's overheating so if you don't know what's causeing it take it to a mechanic without delay. I emphasize "without delay"because diesels will quicklyl self destruct from overheating. There are very few water cooled engines that don't use a t-stat.
   / Need more help with my ym2000. (Over heating) #4
"There are very few water cooled engines that don't use a t-stat." Yanmar made quite a few and even quite a few without water pumps.
I sure agree the overheating needs to be addressed. :thumbsup:
   / Need more help with my ym2000. (Over heating) #5
No tstat and not a bad waterpump, unless the fan is into the radiator. Make sure the radiator fins are clear and back-flush the system.
   / Need more help with my ym2000. (Over heating) #6
How fast is it over heating 5 min blow out radiator fins with air if that dont help check the over flow bottle for bubbles could be a head gasket let us know what you find.
   / Need more help with my ym2000. (Over heating) #7
Compressed air is best for blowing out radiator.
Water just turns the dust/pollen stuff to mud like and it sticks on. It's gotta be dry, and blow it out with air.
If that don't do it,and radiator is clear...you ain't flowing water well enough. Could be pump, or could be cores in radiator plugged
Tried back flushing and it seems like it takes all the water hose pressure. Oil is clean so no blown head gasket.
Just doesn't seem to be enough flow. Water isn't moving much at 800 rpm. 1503874233904.jpg
   / Need more help with my ym2000. (Over heating) #9
I remember seeing on something one time where the propeller broke loose from the shaft on the pump. Just a thought. Wouldn't be hard to pull the pump and have a look.
That would make since. Think all pull the pump.
1798 (A58375)
1798 (A58375)
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2286 (A58376)
2286 (A58376)
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58216)
2008 MOTIV...
(3) FUEL TANKS (A52708)
(3) FUEL TANKS...
