17 Oaks
THANKS!The higher the octane the fuel is, the less chemical energy it actually has in it. The advantage of high octane fuel is resistance to predetonation (pinging or knocking) that will quickly destroy an engine. Higher octane fuel makes high performance & higher compression less likely to run into these issues.
Modern cars have a knock sensor in them & will ****** the timing at the cost of power & mileage if they detect pinging/knocking.
So basically run what the manual says & don't waste your money on anything higher octane.
This should be made a sticky on every forum in the US that even mentions cars as sooner or later someone will SWEAR they get better MPG, more HP/Torque, less razor burn more stations on their radio, etc when they use the higher octane fuels.
On the old Jeep Wrangler I 6 engine its a 8.9 compression, which means it will burn almost anything your can pour into the tank, yet some people swore that putting 93 octane in the engine gave it the performance of a V8 and more...useless if you don't have the compression and cam profile to support it.
