Car hauler vs landscape utility
   / Car hauler vs landscape utility
Came real close to buying the Big Tex 60CH 16' a few weeks ago. I've debated a lot, gone back and forth between car hauler and landscape utility, back and forth between brands, etc... Think I'm finally settled though. Going to see a PJ Utility 16'x77" tandem tomorrow. Unless I find some reason not to when I get there, I think I'll be bringing it home with me.
PJ Trailers | 77" Tandem Axle Channel Utility
Finally picked up a trailer today. Went with a PJ Utility, 16' tandem. Haven't hauled anything with it yet obviously, but towed it about 120 miles home. Tows pretty nice empty anyway; way smoother than the single axles I've used.
I looked at a lot of trailers. I have to say, I'm most impressed with this PJ trailer. The welds are clean, wiring is by far the cleanest that I've seen, the lighting isn't mounted in places where it's bound to be broken off. Aluminum fenders I think are a good idea, no rust and they're removable for when it's time to touch up the paint or if something gets damaged. The rails are removable which I really like. I went back and forth on car hauler or utility many times largely because there were pros and cons to the rails. I figure this gives me the best of both worlds. Just hope the powder coat holds up.
Hope it hauls well. I'll probably use it this weekend.
   / Car hauler vs landscape utility #43
Very nice. Congrats.
   / Car hauler vs landscape utility #44
I've thought about adding a second trailer - this one for hauling my scut as needed. And like most guys - "thinking about something" of "just looking" is casual - and then there is the actual "looking looking".
I'm amazed at some of the things I've discovered in the last 3 or 4 weeks looking at open trailers (utility and car hauler):
1. I've found new trailers that come in 13 and 16 foot lengths that are single axle - available with a 5200# axle or a 7000# axle and they tilt - which is an attractive choice for hauling a tractor or mower. Configuration is that of a car hauler appearance. PJ Trailer is one brand but I found two other brands in 16 foot that are quite similar concept too.
2. I've always been impressed with Sure Trac's galvanized trailers - a format like a utility in single and tandem axle.
3. Too often - I've now seen steel untility type trailers that are built "too heavy". I don't mean "strong" I mean "heavy". In other words - many trailers look the same - but the quality of their steel or their design of construction vary greatly.
4. But far and away - the biggest thing I've learned is what you often don't see - not the welds, not the design, not the gates or axles or tongues or flooring; its the paint preparation process and choices.
a. some trailer makers give you a huge quantity of purchase choices including - bare metal, unprimed, sandblasted, acid etched, primed, epoxy primed, powder coated, car/tractor paint coated or epoxy painted - or several of these combined. And then there are colors too (I counted as many as 6 color choices without getting custom.
b. I wondered why a friend bought a name brand dump trailer and it started rusting and paint peeling within a year. Guess why? Apparently the dealer was working on getting inventory that was cheaper to buy - so they ordered products without primer or etching.
c. Some brands (small brands) are built with a set standard of acid etched, epoxy primer, and either powder coated or painted. Nice thing about those brands is you aren't "guessing" at the dealer's location what you are getting.
5. My point is - buying trailers used to be "what you could see" like welds and pockets and metal thickness, pipe or angle, etc. - and everyone primed their trailers - so a dealer's situation was inventorying and selling. Now its not so simple - and researching model numbers and "options" has become much more important because the exact same manufacturer and trailer model number - can have many different option choices which changes the longevity and future appearance of that trailer.
   / Car hauler vs landscape utility #45
Hey guys, I'm new here but not new to other forums. Please excuse my ignorance.
I have a similar question as to the original poster of this thread. Here's what I'm looking at
JD1025R sub compact trailer. 14'4" ~1600lbs per JD. Pulling with a GMC 1500 5.3.
Im considering a 16' utility or a big tex 60CH car hauler for the obvious reasons of no gate, make my own sides if i want, etc. Also considering a 70CH and other options but I'll keep it simple for now. My question is more specific to the big tex for those of you who have one, but I'm pretty sure most CH style are similar in this regard.
Main question I have is, when you attach the ramps on the 60CH can you adjust the track width for my small tractor vs a car? The girl at big tex said no as did the dealership but all the images and stuff I have seen online looks like they normally sit on a rail and can slide left to right as needed. I'm hoping that the case. The CH is literally only $100 more
The ramps on the 60CH I looked at hung on a rail as you described if I remember correctly. I know I had zero concerns about that when I was looking at it and almost bought a 60CH at one point. So you should be fine.
   / Car hauler vs landscape utility #47
Perfect. I'm hoping to go confirm tomorrow. Thank you.
   / Car hauler vs landscape utility #49
I bought a Big Tex with the mega-ramp option. Full width ramps that fold up for a flat deck.
   / Car hauler vs landscape utility #50
Mega ramps are great until you have to fold them up. That being said I still prefer mega ramps.
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
1996 Moxy MT30S Haul Truck (A55272)
1996 Moxy MT30S...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
LOT: Evercraft 3-1/2 Ton Floor Jack, 12-Ton Bottle Jack (A59076)
LOT: Evercraft...
