GC2310 Hydraulic System Problem
   / GC2310 Hydraulic System Problem #41
That does not make sense to me. If the shaft is too short to engage enough surface on the inside of the gear it drives, to withstand the amount of force it receives, and those forces shear off the pump shaft, and or the gear it drives when it fails, that is not a lubrication issue.
The good news here for me is, if Willie's made it to 900 hrs. mine could. Now that my property is finished, at 25 hrs. or less per year, I may not live long enough to see it.
   / GC2310 Hydraulic System Problem #43
I have exactly the same problem on my 2007 gc2310. It goes forward and back fine but none of the hydraulics work. Happened suddenly with a snap and woosh. Fluid cloudy but not plugged. I have all the sheet metal off. Removed the main pump and control valve assembly....seem fine. HELP
   / GC2310 Hydraulic System Problem #44
Now I see it....the splines on the shaft stripped off and also inside the drive gear in the case....poop....The pump is pretty easy to change...the gear...I may need to take it in for that one....Thanks all for helping me figure this out. time to warm up the credit card.
   / GC2310 Hydraulic System Problem #45
Yes, that's a classic pump shear. And, the problem was supposed to be fixed by 2007.
How many hours are on the machine?
Please let us know, if MF does anything for you.
   / GC2310 Hydraulic System Problem #46
I bought it new in May of 2007. It may have been a 2006 model...not sure. I have 602 hours on it...worked pretty hard but maintained. I have also always had a problem with water or air (turns milky) in the hydraulic oil. not sure why...I change it and the filter often. I set up a 10 foot piece of 4inch PVC on a pole vertically with a valve on the bottom. The fluid goes in the top and settles...water comes out first and then clean fluid...strain it and reuse. I will ask Massey if there is any assistance, thanks. Even if it's just the parts, that would be great. Do you know of any source of parts other than Massey?
   / GC2310 Hydraulic System Problem #47
Thanks for the reply.
I am sure there is no other option for the gear. The new version is supposed to have a deeper throat. That has not been confirmed though.
There probably are pumps that would work. The shaft length, and mounting style, seems to be somewhat common. But, I have found it difficult to navigate the online information pertaining to them.
I have not gotten a recent cost for your repair job, but it's not inexpensive.
I expect they will offer you the parts, it may take some effort though.
At some point, I would imagine they are going to wash their hands of this, and stick us with the whole bill.
We have not had members with milky fluid issues. I assume yours is parked outside?
   / GC2310 Hydraulic System Problem #48
OK..ordered the parts today...I am doing the repair myself. Pump $403 New gear is improved with longer throat..$120 plus I ordered new bearings (2) at $23ea..
That plus a new fan belt while it is apart tax and freight $629. No help but I figure I am saving about $1200 in labor. I have never worked on a tractor before, but I was a car mechanic for several years. I bought a service manual and parts manual (mainly for the exploded views) from AGCO which helped. It will be a couple of weeks, but I will let you know how it turns out.
   / GC2310 Hydraulic System Problem #49
Thanks. I assume MF was of no help.
Some pictures, and insight would be great.
It seems the gear is the first thing that goes inside the case, and everything pretty much as to come out, to get to it.
Keep an eye out for debris.
Good luck. :thumbsup:
   / GC2310 Hydraulic System Problem #50
David my gc2300 just bit the dust , i am down to the pump, i removed the floor and exposed the pumps , pressure washed it and drained the oil, i pull the screen and small metal pieces of metal so now the shaft that has the fan how do i remove that joker as there seems to not have play,
any help would be greatly appreciated .
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2024 John Deere 6110M MFWD Tractor (A53485)
2024 John Deere...
2023 INTERNATIONAL MV607 21FT ROLLBACK (A54607)
2023 INTERNATIONAL...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
