Can anyone tell if this well is bored or drilled by looking at this pic?
   / Can anyone tell if this well is bored or drilled by looking at this pic? #11
Just looking at your picture I would guess that you have a bored well;
View attachment 521292 I tried to attach a image of a bored well and it didn't work well Search for shallow bored water well.
A bored well is the modern equivalent of a dug well, normally done with an large auger, than lined with a casing of some type.
A "drilled" well can be done in a couple of different methods, the newest is a rotary drilling machine which can get lots of footage
in a day by using high horsepower applie to a drill bit with high pressure "mud" being injected down hole to lubricate the bit and flush the
drilled material to the surface. Some people are convinced that a rotary water well drill will seal and plug some of the smaller veins of water
between rock layers.
The other "older"method of drilled water wells is done by using a pounder, a heavy bit is raised on a cable an then dropped repeatedly to drive
a hole in the ground and also to drive the casing into the ground, a pounder, driver is believed to fracture the rock surrounding a well to
enable the small veins of water bearing material the well bore passes thru to enter the bore and the combination of lots of small veins can
create a good well as well as locating the larger veins of water. In some areas driven wells will produce good water flow rates at less depths
then rotary drilled wells, as much as 100 ft compared to two to five hundred feet.
I have a 220' drilled well.
I originally did not think about the drilling mud having plugged some of the minor fissures.
Pump sits at the 200' level, to allow for sludge to fall.
My well GPM has increased over the 12 years since it was drilled.
I attribute this to the gradual opening of small fissures in the rock that were initially sealed by the drilling mud.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #12
Drilled rotary well the cuttings are continuously flushed out usually through the annulus.
Bored rotary well the drill bit is pulled every time it fills up and then emptyied at the surface.
Cable tool rigs use a bailing bucket to remove cuttings.
Baptist type rigs use the tubing as pump to bring cuttings to the surface. The tubing is raised and dropped and rotated. A bit on the bottom cuts the hole.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #13
I would have thought so, too, but this thread made me look into it.
Difference Between Drilling and Boring: Drilling vs Boring Compared
That's interesting. I read the link, but existing tools for making holes don't always fit either
category perfectly.
A Tunnel Boring Machine (TBM) is a drill by the link's definition, since it makes the
initial hole.
A Posthole Digger (PHD) is also a drill by that definition.
I use a "boring bit" on my lathe to make existing holes bigger, but only from one
side. I use a "reamer" or drillbit to make a hole bigger otherwise.
I had a well drilled here in the 90s and the process was very interesting as they
used a smaller bit initially, then enlarged the hole to something like 8.75" with a bigger
tool. Water and bentonite (driller's mud) were pumped down the annulus in both processes.
I also had some holes "drilled" with 2" carbide-tipped drill bits that used air power
for both rotary/impact action, and to eject tailings. The annulus was used to
inject the air, then concrete was pumped thru it to anchor the bit in place. These were
tiebacks for a retaining wall, about 30 feet long each.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #14
Go to your County Planning & Zoning/Development office. They will have everything you want to know about your well on record. And it's free.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #15
Drill Rig: Boring, cable tool, baptist, rotary.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #16
In my area, the county health department issues well permits and they keep the permits in their records. If you have to pull a permit to put in a well it is likely the paper work is on file. A quick conversation with the building department will tell you who you talk to get the building permit, as well as other permits, which should lead you to the department dealing with wells.
Our well goes down 223 feet and is capped with a concrete pad. My understanding is that the pad is to prevent ground water from going down the well casing.
Later,
Dan
   / Can anyone tell if this well is bored or drilled by looking at this pic? #17
Around here they mostly use big rotary drilling rigs, our good water table is 80-100' deep. New neighbor had one drilled a week or so ago, it took less than eight hours start to finish.
When my neighbor to the north drilled theirs the driller started with a hammer rig, got down about thirty feet or so a jammed the bit between a couple of big boulders and could not get it loose. A few days later they brought in a rotary rig about four times bigger than the hammer rig. They tried pulling the bit with that and just ended up parting the cable several times. Finally gave up on the first location, moved over a bit and drilled a second hole. Our geology around here is formed by ice age glacier activity and there are a lot of really big rocks under the surface.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #18
Here in CA, they cap the well with concrete, but also seal the top 50 feet with concrete pumped down
between the casing and the raw hole. It is called a "sanitary seal". The state (not county/city) governs
well permits and inspections, and mandates that you can't pump water less than 50 feet
from the surface.
I always wondered how the concrete seal depth is controlled. I know my well driller ran out of
concrete in his truck and had to get more. It was more like soupy mortar.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #19
This is similar to the cementatious grout used for sealing the oil wells after drilling.
   / Can anyone tell if this well is bored or drilled by looking at this pic? #20
I didn't find much on the difference when used about wells, but perhaps comparing these two videos gives a clue:
3 inch bored water well being drilled (bored actually) Lostant, IL - YouTube
Watch a Water Well Being Drilled - YouTube
That's an interesting link "the difference between" and it doesn't seem to have been written by knowledgeable people. In my 30 years as a hydrogeologist, drilling and boring are interchangeable in describing making a circular hole in the ground (vertical or horizontal as in the TBM). Terminology changes depending on area. For instance, in Kenya a "borehole" is one that has been drilled using air-rotary or mud rotary techniques, while a "well" is one that has been dug. What the link describes as "boring" (enlarging an existing hole), is called "reaming" in the drilling business. Drill a pilot hole with a smaller bit, and ream it to a larger diameter using a bigger bit.
Drilling rig drilling a borehole for water supply using air rotary techniques. Rapid method of drilling in hard conditions such as in bedrock.
Drilling rig drilling a boring for landslide evaluation using hollow-stem auger techniques. This method allows for the collection of relatively undisturbed soil samples in unconsolidated material.
The overall point is don't get hung up on semantics. Drilling and boring in most parts of the US are interchangeable.
208315 (A58376)
208315 (A58376)
2016 FORD FUSION SS (A60430)
2016 FORD FUSION...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
Fecon FMX 36 Excavator Mulching Head (A59814)
Fecon FMX 36...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
