12kw Isuzu Diesel Generator
   / 12kw Isuzu Diesel Generator
One problem with diesel generators is the need to KEEP them loaded. Run too long under a light load and you stand a chance of wet stacking the engine.
I have a 10KW diesel backup generator we use during power outages. For prolonged outages like the hurricane we just had I find myself searching for ways to keep it loaded. It will run my 3.5 ton package AC with the rest of the house but the outside temps during the outage were 65 degrees so we didn't need it. After I had the water heater warmed up and all the laundry done we had to resort to baking cookies. I would not want to search for ways to keep it loaded 24/7.
For an off grid house I would definitely look into solar with a backup generator. Most of the research I've done on this indicates it won't be cost effective if utility power is readily available. If it was going to cost 20K plus to connect to the grid I would rather spend that plus to stay off.
So by the knowledge your presented I should go with the smaller 8kw Isuzu and keep it under probably half load 24/7..I could do that no problem. I don't think an 8kw gen runnin at 4kw could cause wet stacking but I could wrong.
I appreciate everyone that's shed light on the subject
   / 12kw Isuzu Diesel Generator #13
Wet stacking should not be a real concern. Even running under a light load, the exhaust temps stay high enough to keep things clean. Most diesel gen sets never idle which is the biggest cause of wet stacking (like trucks sitting all night idling).
paul
paul
Thanks for clearing that up, Paul
   / 12kw Isuzu Diesel Generator #15
How much per hour do you think a gen set will cost you to run, in fuel cost??
I have several generators now and I've had several others in the past... I have yet to see a generator that will run any where near what grid electric cost...not even close, especially with a 4.5kw load!
SR
   / 12kw Isuzu Diesel Generator #16
I dunno. My generator runs at or below a gallon per hour. More like .7 GPH. My electric bill this month was $277 but it is higher than our usual bill. Funny thing is that comes to exactly what I paid for a gallon of off road diesel at $2.59 per hour.
   / 12kw Isuzu Diesel Generator #17
Your math is way off. No generator , gas, diesel, natural gas or propane is even close to as cheap as grid power.
In your example, .7 gals per hour is 504 gals in a 30 day month. At $2.59/gal that is $1305.13
   / 12kw Isuzu Diesel Generator #18
If he's one of those people who got a multi hundred-thousand-dollar quote to bring power up to his house I can see where it would be cheaper then going on the grid.
Aaron Z
   / 12kw Isuzu Diesel Generator #19
Aaron Z
That is something I had not considered.
   / 12kw Isuzu Diesel Generator #20
You are right! I divided the hours by the cost. I should have divided the cost by the hours. that comes out to 38 cents per hour. DOH!
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
New Land Honor 9200 LB Ratchet Binder And Chains (A53002)
New Land Honor...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
18ft Refrigerated Box for Cab and Chassis Truck (A51573)
18ft Refrigerated...
