DieselBound
Elite Member
No, do not expect to be inconvenienced every 40 hrs for a full/forced regen. Will you have decreased power when a passive regen takes place? Yes. Run the RPMs up a little higher and continue what you're doing; for me this is really no issue, other than having a slight anxiety attack as I see a red light on the dash and then have to focus and decipher what it is. Like I said, I believe that I've only ever had one full, forced(?) regen. I cannot say when that had last happened, but I've now got 215 hours in which case the average occurrence so far is once in 215 hours
(could happen the very next time I run the tractor! but that would average out to say once every 100 hours or so) If that light isn't coming on then the dealer should be forced to resolve THAT issue, and dealing with this issue might, I reckon, expose what's really going on here with regens. Something in your regen system is not right: and I doubt it's only a light issue. Force the dealer to deal with this, but maintain a cooperative stance (you're both in this together).
So, go out and use your machine. If it works then keep using it. If there's an issue get the dealer to get you working (properly).
