heavy exhaust smoke w/ decreased power
   / heavy exhaust smoke w/ decreased power #31
You shouldn't need to have anything relaced. The tractor needs a Regen cycle. The tractor will not regen if the cel light is on. This means the tractor had been ready to go into auto-regen, but auto-regen was cancelled twice. Auto-Regen will be cacelled if the tractor rpm's drops below 1700rpm any time auto regen is asked for. Sometimes you can start the tractor cold, have no cel light and get the tractor to do a manual regen. Start the tractor at idle, set the parking brake, and push and hold the regen button for 3 seconds. If you see the "regen in process" light on the dash, you have a good chance the regen process will complete. Manual regen takes about 43 minutes. If it won't complete the regen, call your dealer. He has a way to force the regen and get the tractor back to a clean condition.
In the future, make sure you ALWAYS operate the tractor above 1800rpm. If the tractor wants to do an automatic regen, it needs two paramemters:
1800 engine rpm
exhaust manifold heat
If it sees these 2 conditions are satisfied, it will go into auto-regen on it's own and complete the regen cycle. The only thing you really notice in the regen-in-process light on the dash. Auto regen generally takes less than 10 minutes. But...if the engine rpms drop below 1700 during the process, it will cancel the regen. The tractor will allow 2 "cancels", then throw the cel light and reduced power.
Best way to operate the tractor is at 1800rpm or above all the time. The tractor will take care of itself and you should never need to do a manual regen.
Hope this helps.
Thanks for this info, MIE!
If you cancel a passive regen, either purposefully or accidentally, can you expect anything different on the next tractor startup? For example, will the passive regen light be on right away (and passive regen will start again automatically once the 2 required sensor conditions are met)? Is there any sort of audible alarm? My main concern about DPF regens is that I could miss that a passive regen is underway (hearing protection + operation in daylight) OR someone (brothers are good for this) else is on the tractor that doesn't understand the system and what is happening and shuts it down. Honestly, I'm not concerned about DPF systems in terms of engine reliability. I caught the first passive regen underway and elevated the throttle to make sure it would finish and it went seamlessly. I just wouldn't mind a little more intrusive notification about regen requirements considering what happens if you don't allow the passive's to complete.
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A51248)
UNUSED RAYTREE...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Adams 5 Ton HC Spreader (A53473)
Adams 5 Ton HC...
2018 HINO 195 16FT BOX TRUCK (A53426)
2018 HINO 195 16FT...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
