hooking up a JD CX 20 shredder with more hoses than I have SCVs
   / hooking up a JD CX 20 shredder with more hoses than I have SCVs #1
San Marcos, TX
John Deere 6615, JD5200, JD850; CaseIH JX70
Hello Tractor Pros!
I just got a used JD CX 20 Shredder, which has three hydraulic hoses, each going to a single action cylinder. These run: one for each wing (up hydraulic, and down by gravity, I assume); it has one for the height control on the center unit (also single action, with only one hose).
My problem is that my JD 6615 has only 2 SCVs.
What is my best option, assuming I want to run the wings independently? Alternatively, how would I get both hoses for the wings connected to one SCV control, if I have to run them together? Should I attach the hose to the upper or lower SCV quick connect; does it matter?
I do have a loader on the front, which has its own hydraulics, and the CX 20 is pull type, of course, so the three point/rockshaft control is available, but how to connect there?
Should I run a hose from the loader, when I am shredding, to get that independent action? How would I get the loader control to "float"?
Any input is appreciated; I am new to this site, so please forgive my ignorance or any breach of etiquette.
   / hooking up a JD CX 20 shredder with more hoses than I have SCVs #2
:welcome: to TBN
Check with your Deere dealer for a kit to add SCV's to your JD 6615. That would be the best if such a kit is available.
   / hooking up a JD CX 20 shredder with more hoses than I have SCVs #3
You can get a kit installed or make a splitter. Using one scv and Y it for 2 hoses to run. Don’t need tons of pressure so this will work to raise wings together. I’ve done it before may take a bit to raise but it will work
   / hooking up a JD CX 20 shredder with more hoses than I have SCVs #4
Welcome to TBN
Ditto on attaching wing cylinder hoses together with a "Y" or tee. One could also utilize a Fasse valve similar to photo below
   / hooking up a JD CX 20 shredder with more hoses than I have SCVs #5
You have removed the loader when shredding, I would run hoses to the loader hookup. For float, push the joystick forward, it should go a little more into float.
   / hooking up a JD CX 20 shredder with more hoses than I have SCVs #6
The CX20 shares parts with the HX20.
CX20 has individual cylinder control and the 3-port control valve is shown in the Parts Catalogue which allows separate Wing & Lift control:
Part #BW15063
The HX 20 has the Wing Cyl'rs 'Teed' as suggested above. The T-connector is shown as Part #38H1205 (Item #5)
   / hooking up a JD CX 20 shredder with more hoses than I have SCVs #7
T the wings together. No need for them to be independent that I have found enough to justify adding an scv. On the scv covers, plug it in the one that shows the cylinder extending. I think it's the bottom one on mine. When shredding, leave the wings in the float position so it'll follow the land better and you'll get a great cut.
Brett
Great! Thanks to all for the advice. Looking forward to it.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2005 Peterbilt 387 with Wet Kit (A61306)
2005 Peterbilt 387...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
FUEL CELL (A58214)
FUEL CELL (A58214)
