Secret to hooking up PTO shaft
   / Secret to hooking up PTO shaft #91
I have several type of couplers and seems sometimes it is quick and effortless, and other times nearly impossible. I read through the posts and saw some good ideas.
My trick, that I just began using this year on the tough ones, is to:
1. Make sure the pto shaft is lined up as straight to the tractor as possible,
2. Straddle the pto shaft
3. While using both hands to pull on the collar, push the shaft in by squeezing it forward with my knees.
Haven't had this fail yet, and seems to slide in much more easily, maybe due to the pressure coming from both sides evenly.
Hmm....are you Ron Jeremy by chance?
   / Secret to hooking up PTO shaft #92
Thanks to whoever turned me on to puttimg the pto rear/mid selector into neutral. Works slick. As for lube, I use Never Seize on the splines and slide. Seems to really stay on anything. Including my clothes and hands.
   / Secret to hooking up PTO shaft #93
Use Fluid Film or Slick Stuff. Much less messy.
   / Secret to hooking up PTO shaft #95
Fluid Film is actually very good for your skin AND smells nice! It's the lanolin.
I also use it in my hair :D Oh, WAIT! What hair? :eek:
Slick Stuff also smells great. But just about anything smells good after one has been whiffing PB Blaster!
   / Secret to hooking up PTO shaft #96
An Aussie/Kiwi lanolin product "LANOX" is my 'go to' spray-on product. :thumbsup:
Not only does the PTO get a spritz before and after use but at least twice a year I'll go around the tractor and spray anything that mechanically moves (that doesn't already have it's own grease nipple).
   / Secret to hooking up PTO shaft #97
When I hook up the tiller, or the wood chipper, or the stump grinder and am having any problems, I just think of my shovel and my ax hanging in the garage.
   / Secret to hooking up PTO shaft #98
Yeah, or as a friend of mine says, sarcastically, of such problems: "Third world problems!"
Either a slave with a shovel/axe, or a slave to machines... (after a clutch job and suspension refresh on one of my cars I was kind of thinking that I missed manually installing fence posts!)
   / Secret to hooking up PTO shaft #99
With a rotary cutter, lift the cutter so the jumper is off the ground. This way you can rotate the shaft, while rotating it slowly put it on the tractor, it will line itself up and when it grabs, just wiggle it around and it will go right on. Do this with all of my implements and it is by far quicker than trying to line up the splines visually.
   / Secret to hooking up PTO shaft #100
If your tractor has mid and rear PTO, shift to mid when hooking to the rear, and vice versa.
It will allow you to turn the PTO shaft by hand to help with lining up the splines.
Thanks for that hint. I've never heard that before.. :thumbsup::thumbsup::thumbsup:
(2) LP GAS TANKS (A58374)
(2) LP GAS TANKS...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Bucket (A55973)
Bucket (A55973)
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
