Any experience with Titan Box Blades?.
   / Any experience with Titan Box Blades?. #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
I have the opportunity to purchase a titan HD box blade. I will be pulling this behind my Kubota M6060..
I do have some rock that I will run up against at times. J
   / Any experience with Titan Box Blades?. #2
I have a 6' Titan; looking at their website, I see only one "grade" of box blades. If they had an HD unit in the past it may be worth grabbing. Mine is fairly light weight, in terms of both weight and construction, compared to the ones that cost twice as much, so I keep my speed down. I've snagged it on a stump without damage, and pulled up some reasonably large rocks with it. I sometimes put a few sand tubes on top for tearing up dry soil.
I've used it quite a bit with no issues. I suspect high speed use in rough soil may cause things to bend, but if you use caution and you can get it cheaply, go for it.
Attached is the HD model...
   / Any experience with Titan Box Blades?. #6
Per their web site a 6' weighs 530#, 7' weighs 586#, and an 8' weighs 640#.
I previously owned a 5' Woods that tipped the scales at 540#. It had a hinged tailgate. My current blade is a Taylor Way 7' that weighs 640# with a fixed rear blade. The extra weight of the Woods was due to the tailgate.
I consider the Titan as medium duty along with my Taylor Way. A 5.5" Gannon is over 1000#. That's heavy duty.
   / Any experience with Titan Box Blades?. #7
You could easily run a 7' 1000lb. Box blade behind a M6060. The more weight the better it performs.
I couldn’t pass up the deal... Planning on adding some ballast to the top of it. Ill be working in hard dirt.
UNUSED JCT 72" HYD VIBRATORY PLATE COMPACTOR (A54757)
UNUSED JCT 72" HYD...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2007 CHEVROLET C7500 BUCKET TRUCK (A51406)
2007 CHEVROLET...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
