aeblank
I have a log lift...
https://i.imgur.com/8qpa9b2.jpg
First of all, you don't need a log lift, IF you work smarter instead of harder...
Cut all of your wood over a wagon or trailer, then there's NO lifting heavy wood to the splitters beam, just roll them onto the beam!
IF you have a table on your splitter, resplits re no problem at all, at least with mine it isn't. Everything get's pushed through the 4-way,
and the resplits get rolled back over the 4-way, right back onto the beam... Letting the splits go off the end, means I don't have to handle them again to get them off the splitter. Sometimes IF I have the help, they go off the end and right into half cord "drying boxes" that get moved with the tractor,
You just have to buy the right tools and work out a system, it really lightens the work load!
SR
I had wanted a Split-Fire log splitter for years, but kept putting off the purchase due to the high cost, and I didn't want to settle for a 3 point hitch version. I finally came across a good deal on the exact model I wanted earlier this spring.
Since then I hadn't used it much, but I've put a few cord through it and after getting used to it I can honestly say that I should have just paid the money years ago and purchased it new. I've been missing out all this time!
It does NOT require two people, I sometimes cut them off my pallet forks myself...
Work SMARTER, not harder!
SR
I CAN believe YOU wouldn't be able too... ha ha haCutting on a wagon by yourself doesn't seem smarter not harder. I'm not seeing the drastic labor savings by rolling rounds across a wagon vs the ground anyway.
