Sheave block mechanical advantage?
   / Sheave block mechanical advantage? #31
Yes, I was missing a line. So something has to carry the load. Like a crane where the jib or boom carries the load, but the hoist has mechanical advantage via a bunch of sheaves and never sees the full load.
   / Sheave block mechanical advantage? #32
If your arrangement has only those two lines anchored, it will only pull 4000 lbs, not 6000 lbs. (minus friction losses, etc)
If you are pulling 6000 lbs, you have another line you are not telling us about. :D
Bruce
The "rated" pull is usually considerably on the conservative side. I can see a 2,000 lb rated pulling a 3,000 load. Possibly a bit on the extreme side but I wouldn't be surprised.
   / Sheave block mechanical advantage? #33
It would be interesting to see some real world figures as to what these cheap winches can do. Most sound on the verge of death. That Keeper portable winch I got is rated at 2000# and cost all of $110.00 CDN. Comes with nice vinyl battery cables (which look chinsy) and a wired remote.
   / Sheave block mechanical advantage? #34
[video]https://www.google.ca/search?q=pully+mechanical+advantage&ie=UTF-8&oe=UTF-8&hl=en-ca&client=safari#imgrc=RVwuteWB6TBmWM:[/video]
   / Sheave block mechanical advantage? #35
To get around the limiting factor of the winch (or vehicle) capacity, you'd have to anchor to a tree or some other sturdy object. Take Bigtiller's picture above, a 200 pound person could lift a 300 pound weight, because the line he's pulling (winch line) has only 100 pounds of force on it. That's how heavy recovery trucks snake big rigs up from an embankment they've went over.
Oh,so that's how it works? Why didn't someone say so earlier? :duh:
   / Sheave block mechanical advantage? #36
There is a way to multiply your force even more using vector force.
Stretch chain/cable from tree to solid anchor.
Place sheave in middle of chain.
Run winch line through sheave and back to fixed anchor.
A tremendous amount of force can be applied this way from a small winch.
https://www.ropebook.com/wp-content/uploads/2016/11/vector-chart.jpg
   / Sheave block mechanical advantage? #37
I have different take on the issue. What you want to do has hidden dangers might not work as expected. Initially the tree will move in the direction of the force applied but when the rope gets slack the tree is free to fall sideway. So before you cut it make sure that the wind direction is right and the weight distribution of the tree will help you to drop it where you want it. If you tension it with your vehicle or tractor wind force in opposite direction might(unless the vehicle is really heavy) throw it like rag doll. Ask me how do I know it.
   / Sheave block mechanical advantage? #38
I used that on a hazard tree. My F150 2x wouildn't pull any more, Tree ready to go but needed a bit more force. I grabbed the cable about 1/4 way out from the truck and swung my weight from it. Success.
   / Sheave block mechanical advantage? #39
I was going to mention that up thread aways. The tow vehicle only starts the tree moving, from then on it is in free fall. The tow vehickle or winch cannot take up slack fast enough to effect more than the first few seconds. I hung a coupld 5 gallong pails of water from the middle of the pulling cable once to maintain the pull for a few seconds longer.
   / Sheave block mechanical advantage? #40
That's why I ALWAYS use a very long nylon rope with a good amount of stretch. The bad thing is, if there are rotten branches or tops, that jerking of the stretched rope can break that stuff off, falling on you.
When I had to cut a lot of foot or so pines and they had to fall where wanted, I used a steel cable, cut them mostly off in proper felling manner, and ripped them down with the backhoe in the direction I wanted. It worked perfectly and really took a lot of the anxiety out of the operation. Like, when's it gonna fall and where?
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
gravely riding mower (A53424)
gravely riding...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
UNUSED RAYTREE RMSC78 - 78" SOIL CONDITIONER (A54757)
UNUSED RAYTREE...
