Ford 3000 gas fuel lift pump, will it run without it? convert to gravity feed
   / Ford 3000 gas fuel lift pump, will it run without it? convert to gravity feed #1
Larry48
Culpeper, VA
Ford 3000
Just got my dad's Ford 3000 gas. He bypassed the fuel lift pump to try to convert it to a gravity feed system many years ago and I don't know if it ever ran this way. I know he had problems but I don't know what they were. I drained old fuel, replaced sediment assembly, rebuilt carburetor and it started and ran for about 10 seconds. It stopped and I haven't been able to get it started. The sediment bowl remains full but I still don't know if that is sufficient fuel to make the tractor operate properly. Any thoughts or ideas. It does have spark so ignition is not the problem. If I need to reinstall the fuel lift pump can I get the proper fuel lines bent properly to make it look original? I have called several used tractor parts sources in the internet and no one has the original fuel lines. Thanks in advance for your help.
Answered my own question. I put a new fuel lift pump on it and it now runs. Really makes no sense that this did not run well using gravity feed. I guess Ford had a reason to use a fuel lift pump or they would not have put one on it. I understand however that this was an option.
   / Ford 3000 gas fuel lift pump, will it run without it? convert to gravity feed #3
I agree, that pump is probably needed when running on uneven ground up or downhill with a partially filled tank.
   / Ford 3000 gas fuel lift pump, will it run without it? convert to gravity feed #4
The fuel pump was standard equipment on all Ford 3 and 4 cylinder gas tractors built 1965 and later. The Holley carb requires positive fuel pressure for the tractor to perform as designed at full load and in all conditions.
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
TOOLBOX (A52472)
TOOLBOX (A52472)
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2012 L3 MEP-806B GENERATOR (A52576)
2012 L3 MEP-806B...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
