1967 Case 580 CK Vs 1977 Ford 3600 ???
   / 1967 Case 580 CK Vs 1977 Ford 3600 ??? #1
Frankdozer
Bridgton, Maine
1967 Case 580CK Backhoe / Loader
I am looking at these 2 machines. A 1967 Case 580CK and a 1977 Ford 3600. Both machines have a front loader and a rear 3 point hitch. And are the same price. They are in similar condition. Which way should I go?
Frank
   / 1967 Case 580 CK Vs 1977 Ford 3600 ??? #2
Frank
Can't advise on choice, but parts for my 1970 Ford 3400 TLB are still relatively easy to find.
My Ford 3400 is a very close relative to the Ford 3600.
The Case v/s Ford 10 year age difference might make a parts availability difference.
   / 1967 Case 580 CK Vs 1977 Ford 3600 ??? #3
It would help to know how you plan to use it. Both have proven engines, so either would be fine there. If for mostly loader work, as in loading trucks, the Case with a torque converter, and reverser are pretty handy. If it has a manual reverser, w/clutch, the reverser has a weak link. A pretty small roll pin, pinning the shifting fork to the lever inside the top cover. They won't take much abuse, and will wear, or shear. No ram and jam. You must be completely stopped before changing directions. Still beats going from a forward gear, to a 1 speed reverse on the Ford, if it doesn't have the reverser, which some models do. If both have a manual transmission with a clutch, you just have to watch, and not slip the clutch, or you'll end up with a grabby clutch. If the Ford has the dual clutch, it will have a button clutch for the main, and disc clutch for the PTO, if it has one.
The Ford will also have more gear speeds to work with, more than likely a 6, or 8 speed. Where the Case will only have 4. Again, helps to know how it will be used. If you're planning on using a 3 pt. tiller on it, the Ford would be a better choice, for low ground speed. If just pulling a box blade, or 3 pt. blade, either will work fine.
Ford probably has the better brake system. Case works fine too, but if it has not been maintained, I'd almost bet you'll need to redo the brakes. The brake discs get oil soaked, because the bull pinion shaft bearing cage seal leak, after so many hours. Just the nature of the beast, they all do it. The Ford brakes would be easier to service, as they are automotive type drum brakes. Pull the rear tire & wheel, remove the brake drum, and everything is exposed.
Do you plan to use a rotary cutter, or, other PTO implements..?? Does the Case even have a PTO..?? Do either..?? I believe the PTO was an option on the Case. On the Ford, I'd have to guess it was a standard option.
Does the Ford have power steering..?? A very important option if you have a loader. If both do, they both work very well. Speaking as a Case 480C owner, and, an old 310B owner, the steering cylinder does have it's seal problems. Overall, the Ford probably has the better system, as far as repair if needed.
There's probably other points that could be mentioned, just trying to cover some basics. But, just speaking from mostly Case experience, and limited Ford experience. How close to a dealer you are should weigh in there too. Most of the new OEM Case parts will have to be purchased through a Case Construction dealer. Where the Ford new OEM parts should be able to be bought at any NH dealer. There are a lot of aftermarket parts out there for the Case, not sure about the Ford. Both are pretty proud of their OEM parts, as far as price.
   / 1967 Case 580 CK Vs 1977 Ford 3600 ??? #4
The engines are proven & sound.. ofcourse you'll have to check for leaks & blow-by..
The BIG problem w/ Case is the "transmission"..& Brakes..
Cant speak as to Ford..
You'll have to check the trans on the Case in person & DONT take ANYONES WORD as to the operation.!!
Does it move when you drop it in gear?? do you have to wait 5-10-15 minutes until its warmed up??
DO these checks on a COLD engine.. DO NOT let the seller "warm it up" before you get there.!!! VERY IMPORTANT..
PLUS it'll give you a chance to SEE w/ your own eyes how "cold natured" she can be or not be, trying to start it..
Let it run for 3-5 minutes, watch your clock.. THEN drop it in gear..
USE the BHoe.. THEN TRY to LOCK IT IN FOR TRAVEL.. The Case has a "trick".. its widely known to Case users but frustrating to a newbie.. its just a Case quirk..
I cant stress NOT LETTING the seller warm it up enough..
I went w/ a buddy to inspect one once & we TOLD the seller.. DO NOT START OR warm up the engine before we get there..
Sure enough.. the engine was hotter than Hadies when we arrived at daybreak..
THAT ALONE told me he was hiding a transmission problem.. and we passed on "the deal".. a few months later I got a call from the fella that "took the deal"..
HE was none to happy about his purchase.. Tractor had to be split to fix the tranny..
The Brakes aren't any fun either..
Well I review the Ford today and as soon as I said I would like to purchase it ,,,,,, the seller raised the price by $500.00 . Needless to say .... I did not buy it.
Frank
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Chevrolet C8500 Flat Bed with a Moffet Kit (A55218)
Chevrolet C8500...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
