Seafoam
   / Seafoam #361
JUST FOR EVERYONES INFO, Seafom wont cure everything. I had a weedwhacker that I thought had a carb problem and used Seafoam in it. Ran it, let it soak in a 50/50 mix and no change. It cranked good, idled good but wouldnt rev up. I set it aside for about 8 months with the Seafoam in the tank. A couple days ago, I thought let me check that again. Still same issue, it cranked on second pull but still wouldnt rev up. I was going to a small engine repair place to get some saw parts so, why not take in the weed whacker.
Got it back yesterday and $27.50 later it runs like new. VERDICT: The engine had a fine screen (spark Arrestor? maybe) on the exhaust which was about half stopped up with carbon buildup. The shop completely removed the screen and now it runs great.
Just thought I would pass this tidbit along in case someone else has come across the same problem.
PS: The shop said that the carbon was from incomplete combustion due to running the engine at less than full throttle. I had been doing that quiet a bit when using a steel blade attachment for cutting sawbriars and other vines along an old fence line since many times I would be hitting hitting rocks and old wire among other immovable objects so I didnt want it turning full throttle.
Thats very common with WW, I soak the exhaust in gas overnight then runs like new.
   / Seafoam #363
I agree and the equipment could leap tall buildings in a single bound. Indeed both products seem to work as advertised, something highly unusual today
   / Seafoam #364
I just royally screwed up my 20 year old Sears ride on with a 17hp Kohler using Seafoam down the carb look me up to read the tale. Proceed with caution. I was able to fix my problem but I was shopping for a new one and not a happy camper.
   / Seafoam #366
I do. Learned about it from the "big guns" on a boating forum. Haven't been without it since in all types of engines.
   / Seafoam #367
I did, it was a good story.............Now I'll look up this Seafoam stuff, never used it, I know I live in a cave.
   / Seafoam #369
Respectfully I'm not sure if it was the SF or how it was used.:confused3:
   / Seafoam #370
Guess this stuff does work, what a difference on this Ford Ranger>> Seafoam--can't believe what it did to my engine!! - YouTube
I've used it for years in small engines. This Spring was a good example - my Briggs push-mower: has had better than average to Good maintenance and fuel (and a new plug late the previous season), but was running slightly rough. Dosed @ close to the recommended amount, after about 3 minutes it was purring like it should.
Like Gary's example (output-side restriction), SF won't cure everything, and it usually needs some flow through a carb jet to allow it to get to work....... if a carb has sat long enough that the jet is totally plugged, you may need a new jet, et al.....
I'll also use SF as a fuel injector cleaner in road vehicles - many gas engines don't have fuel filters anymore, and using a cleaner once in a while can help.
I don't like dosing with SF in really high concentrations - I'd only do it in an emergency (ex. extended power outage, only generator down.....) - if your problem is that pronounced, then a carb tear-down/replacement is probably in order....
It's actually a very old product..... legend has it that it all came about from the founder's love of fishing....
Rgds, D.
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
2239 (A51244)
2239 (A51244)
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
