5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 26,997
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Heck, I've run scrap dimensional lumber through my Jinma, no issue. I've even chipped a few PT 6x6's. One thing I learned with the Jinma that might apply to the others is that the faster you run the machine the coarser the chips are so I run mine about 1/2 to 1/3 rated pto speed. That produces the best length chip for me. I've read about plugging at lower speeds on all brands so to insure I have plenty of ait moving in the flywheel area, I pulled the back knife access cover and drilled 2 rows of 8 1/2" holes in the plate to allow more air in and that seems to do the job as I've never plugged mine. I've got way more than 25 hours chipping time, the machine probably had a couple hundred hours on it when I bought it...
I know it's on it's 4th set of knives and the drive belts were replaced at least one time. It's needing a new infeed driveshaft soon. Woodmax has them in stock. Mine was a good investment, especially good finding a used one which I think is rare or at least not common, I've never seen a used one around here except the one I happened on, on Craigslist.
Mine only digests wood. If it had a shredder plate (which it don't), I would consider it to be capable of hammermilling garden residue.
They are all inherently dangerous machines. You want to be very attentive when using one and never allow kids around it when it's running.
I see the newer ones that Woodmax sells now have a kickback shield in the throat area, something I'm going to retrofit. I've had a dew chunks of wood deflect back when chipping and they come out real fast. I've learned not to stand directly behind the chute but rather to the side and I always wear safety glasses and hearing protection, it's a loud process.
