Texasmark
Elite Member
- Joined
 - Apr 24, 2012
- Messages
 - 3,715
- Location
 - N. Texas
- Tractor
 - Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
Try to reposition the unit, some times depending on how some thing sets will seal off the path for the grease to get into the shaft/bearing, especially if there is tension on the area where the grease goes in,
I have a lift on a disk and to get grease in it one needs to set the disk on the ground and raise the wheels if pressure is on the wheels you can not grease this zerk,
That works. Also have used a drill bit to see if any material is packed inside. Zerks are easily obtainable and cheap. I'd just go with new ones after you do what BHD suggested. If you aren't sure what position that is, with your new zerks installed, have someone run the controls or run the grease gun while you work the controls putting the machine in different positions.
