Woodmaxx vs Landpride 3 pt snow blower?
   / Woodmaxx vs Landpride 3 pt snow blower? #1
Rob 80
WVA
B2650
I'm looking at buying a 3 point rear snow blower for my Kubota B2650, i have found one from WoodMaxx the SB-60 PTO Snow Blower online for $2,249 or a landpride SB1064 my local dealer has the SB1064 in stock. I'm sure it will cost more just waiting to hear back from them on the price i will be surprised if it's under $3000 it's new and a 2017 model Standard Crank.
The WoodMaxx weighs 695 lbs, i wonder if that is with it's shipping box.
The landpride weighs 501 lbs
My wifes thinks i should get the local one since i wouldn't have to mess with delivery and since you can see it first. Is the woodmaxx taller than the landpride? It's really hard to tell going by only pictures. It also looks like the landpride does not come with shoes so that is a added cost.
   / Woodmaxx vs Landpride 3 pt snow blower? #2
The Landpride 1064 has skid shoes so no worries there. If you buy the one that your dealer has in inventory now
you can be sure you will have it when you need it.
Like most anything else you can add the bells and whistles like hydraulic controls later.
If the 1064 can be run by your mule you will be able to clear snow as long as you do not try to move to fast in reverse.
   / Woodmaxx vs Landpride 3 pt snow blower? #3
   / Woodmaxx vs Landpride 3 pt snow blower? #4
I have the woodmax 72in pto blower and am very impressed with it. Had a Kubota blower on my previous tractor and the Woodmax is @ least its equal. This is a very high quality and effective blower for the money.
   / Woodmaxx vs Landpride 3 pt snow blower? #5
I would rather see you invest in the Landpride unit ONLY because your dealer has one unit in inventory and you can obtain the parts to upgrade it locally.
You are dealing with the potential of not being able to purchase a snow caster if you do not purchase the local unit or have a pronovost/allied farm king/lucknow/normand unit shipped to you soon as the number of preexisting orders will affect the ability of the manufacturer to ship a unit to you.
   / Woodmaxx vs Landpride 3 pt snow blower? #6
I have a B2650 and I will be purchasing the Landpride SB1064 as soon as I save up the funds. I too looked at woodmaxx and a few others, and even though woodmaxx is cheaper, I am still going with the LP, mostly because of it being a local dealer, I know it will fit my quick hitch, its color matched and I can get parts locally too.
Think i will be getting the LP for the same reasons.
What skid shoes should i get with the Sb1064 for a gravel driveway? There's a few inner shoes, outer shoes, outer wear bar, lower wear bar.
   / Woodmaxx vs Landpride 3 pt snow blower? #9
Any new opinions on this 4 year old question?
$6k for a 74" LandPride with power angle & deflection (don't remember if that was electric or hydraulic) on m my dealers lot right now.
Just under $4k for a 72" Woodmaxx with either electric or hydraulic controls.
My L4060hstc is set for a 72" track. Possibly a hair wider as sidewalls bulge. Might upgrade to a L6060hstc at some point, but would still set it to 72". The extra 2" on the LandPride might be nice, but probably not critical.
I've gotten by with a SSQA plow for 4ish winters now on the L4060. Lots of huge drifts here in Colorado, so looking for a blower when the plow won't cut it (or can cut it only back dragging a scoop at a time). Local dealer service is nice, but in a pinch I could handle the blower being down.
   / Woodmaxx vs Landpride 3 pt snow blower? #10
I don't have a Woodmax snow blower, but I do have one of their chippers....very nice quality and I do recommend Woodmaxx products.
That said, availability of the Woodmaxx snow blower might be a problem this late in the season. I had to wait a few months for the chipper as these are manufactured in China. I assume the snow blower is as well
LandPride also makes great equipment (had one of their rotary cutters a while back) and the unit is available right now.
My suggestion is go with the LandPride. As far as the width, you can always add wings (those might even be available through LandPride) which will give you 2-4 more inches of width
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2008 PETERBILT 367 HOT OIL UNIT (A53843)
2008 PETERBILT 367...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2014 KENWORTH T800 MIXER TRUCK (A53843)
2014 KENWORTH T800...
