2x4 Lumber Law Suits Dismissed?
   / 2x4 Lumber Law Suits Dismissed? #22
I'd like to actually see some of those allegedly perfectly straight 2x4s! They sure don't sell those at any of the big box stores around here.
   / 2x4 Lumber Law Suits Dismissed? #23
Not here either. All their lumber and plywood is warped and twisted. I get anything I need from a real lumber yard. Top quality for not very much more. I just shake my head when I see guys headed out the door with stuff that I would throw straight into the dumpster.
   / 2x4 Lumber Law Suits Dismissed? #24
My local lumber yard is not much better. They look fine when stacked in their yard but it's a 50/50 proposition as to whether they remain that way when I let them lie around for a few weeks.
   / 2x4 Lumber Law Suits Dismissed? #25
If you framed walls with full 2x4 lumber...even a full 16D nail will only have an inch and a quarter of purchase...
   / 2x4 Lumber Law Suits Dismissed? #26
That is correct. Years ago I did a lot of remodeling in Los Angeles. Those old houses were nailed up with 20d nails in most places. My uncle was a builder in those days, he used to talk about using a hatchet instead of a hammer. That was long before specialized and heavy framing hammers were available.
   / 2x4 Lumber Law Suits Dismissed? #27
I read the story and it seems part of the decision was that they are sold as 2x4 and not 2"x4"...in other words the 2x4 is nothing other than a product name.
Agree. While I haven't read the legal opinion, my first thought was the plaintiff has a snowball's chance in ****. The terms, standards and industry practices will almost always take precedence.
   / 2x4 Lumber Law Suits Dismissed? #28
I remember when they were 1 3/4" x 3 3/4"
Bet you don't. :) My recollection was 1-5/8 x 3-5/8 so I looked it up. Turns out there is a USDA paper on the history of lumber standards. It was all local practice until the 1920's. The Lumber Standard of 1924 set the actual minimums as 3/8 less than the nominal dimension except for 1" thick which was set at 25/32" (although some places continued to use 13/16). Over the years the dimensions 6" and greater were changed to 1/2" less. In 1956, the 1" nominal was changed to 3/4" and in 1961 the 1-5/8 was changed to 1-1/2. I'm not quite sure when the 8" and greater became 3/4" less.
   / 2x4 Lumber Law Suits Dismissed? #29
If you cut your own trees and take them to a saw mill. Around here, they will come out 2x4. only store bought are less than 2x4, 2x6,6x6,etc,.
Yep, used to be all rough-cut lumber was full dimenstion. Only S4S comes out the thinner measure. I bought some 1x4 S4S and that stuff measured out less than 1/2" thiick
Used to be fun trying to remodel an old house built with rough cut. Very difficult to make new lumber match to the proper thickness/width needed.
   / 2x4 Lumber Law Suits Dismissed? #30
Well...they pretty much are until they dry out! I watched them cut the bands on a new lift of 2x6. Pile expanded by about a quarter.
I built a temporary ceiling support of 2x4 to keep the cieling from collapsing when I was working on the remodel. Came back next moring and one of the upright 2x4 had a complete 90* twist from one end to the other. It wa straight when I put it in.
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
