robstaples
Gold Member
Good to know. Plc would support calendar recovery time table but lots of extra work. Unless you like to tinker, commercial products have been tested for bugs.
Thanks.
Thanks.
I am with others who suggest having a large tank with no air/water separator membrane storing water at 60 psi pressure is making matters complicated for no benefit.
my bet is it needs to be 1/4 inch tube which flows 1 gallon per minute at 60 psi.
I have run 1,000 kid high school on a 5 gpm well yield.
If you have things all figured out just go for it. If you want other options than the one you have have your mind fixed on then I for one can only answer your question by saying use a Dole flow control rather than trying to find a pipe which will flow 2 gpm. It does not exist as pressures and lengths vary and all affect flow rate. |The Dole is designed to deal with the variations in pressure while producing a constant output you have selected when you buy it.
If your well pumps at 2 usgpm, add a simple dole flow control for about $30 to the pump output and then it will run keeping pace with the well output.
This explains the operating principle:
This is where you can buy them:
Control Water Flow Rates - Dean Bennett Supply
Store your water in the big tank at atmospheric pressure.
Use a shallow well pump like this $82 one from Home depot to pressure and supply water where you need it.
Acquaer 1/2 HP Dual Voltage Cast Iron Shallow Well Jet Pump-SJC5 - The Home Depot
Having a large atmospheric above ground tank has the added benefit of allowing any dissolved gases to vent off when there is no pressure keeping them dissolved in the water.
Dave M7040
Agreed! You are making this far too complicated!
I used to work in commercial plumbing for a manufacturer's rep, so I had to learn a bit about such systems.
This statement here (among others) says that your misunderstandings are at such a fundamental level that you should not be trying to design this yourself:
