4300 exhaust smoke
   / 4300 exhaust smoke #1
steviep
Milton NH
2001 JD 4300
Earlier this year the engine on my 4300 was rebuilt. Since the rebuild the engine has started and run pretty good except for when it first starts it has a large cloud of what looks like blue smoke. My oil is still full and looks fine. The anti freeze looks fine too. The engine has less than 50 hours since rebuild and it seems to lessen the more it runs. Any help is appreciated.
   / 4300 exhaust smoke #2
How many hours on the engine before the re-build?
Any idea what precipitated the need for a re-build and how extensive was it?
Hopefully the engine will settle in and clear up the smoke problem in due time.
   / 4300 exhaust smoke #3
Blue would most likely be raw diesel or possibly oil. Can you tell which from the smell?
   / 4300 exhaust smoke #4
Could be that the rings never seated and/or not correctly rebuilt? Ken Sweet
The engine had about 1000 hours, the reason for rebuild was a little thing called starting fluid.The engine was bored with new pistols and rings plus the head redone. It was done by a reputable local machine engine rebuild shop. As far as smell I don't know.
   / 4300 exhaust smoke #6
Sometimes a rebuild does not bring a engine back to the performance levels of new. If you don't smell strong diesel in the exhaust, it probably is oil causing the smoke. Hopefully, it will get better as you add more hours. Ken Sweet
   / 4300 exhaust smoke #7
Just throwing this out there.
My 5055e started emitting blue smoke. The problem was a pinched fuel line. Not enough fuel was being injected, which caused poor combustion.
   / 4300 exhaust smoke #8
If you can put it under load do that. It needs a good long hard workout.
   / 4300 exhaust smoke #9
My 4300 has always (17 years) done this, it's normal. Just diesel fumes due to cold engine. Don't worry about it.
   / 4300 exhaust smoke #10
Blue smoke?? My 4400 gives a short puff of black smoke when it starts, not blue.
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2024 New Holland T8.410 MFWD Tractor (A53472)
2024 New Holland...
