I am seeing many people who replace or do wiring on their GP circuit, make serious mistakes.
Some glow plugs are wired in series and some in parallel. It makes a tremendous difference.
Do you have a wiring diagram in your owners' manual which you could post?
If you are going to do your own troubleshooting you need a few inexpensive tools.
A test light
A multimeter
An infrared temperature measuring gun for less than $20 on Amazon
Amazon.com: Etekcity Lasergrip 774 Non-contact Digital Laser Infrared Thermometer Temperature Gun -58℉~ 716℉ (-5�℃ ~ 38�℃), Yellow and Black: Kitchen & Dining
Post some pictures of your glow plugs on the engine along with their wiring.
White smoke means un-burned fuel.
If you can easily do so, disconnect the air filter assembly from the intake manifold. Direct the hot air from an electric heat gun into the manifold as you crank the engine. A hair dryer will also work although not as well.
If the manifold is metal, even a propane torch can warm the intake air and help starting. Watch this youtube video to allay any concerns with the torch.
This youtube video is just to show you how engines were started before Glow Plugs became common . I am not suggesting you change your tractor but rather realized how much heat is necessary to get things firing.
The correct term is Thermostart also known as a flame heater.
HOW THE FLAME HEATER WORKS ON A PERKINS DIESEL - YouTube
Do NOT test your GP's by connecting them to 12 volts. Sudden death of the GP can be the result.
Dave
M7040
