Trade CK35 for a CK2610?
/ Trade CK35 for a CK2610? #1
KenGod
PA
CK2610HST
Im looking to trade my 2014 CK35HST w/ fel, hard roof and soft cab. It has 510 hours on it.
The new unit is a 2017 CK2610HST w/ fel, field cab with heat, front wiper, lights and a new sub frame for my existing bh which Im keeping for the new unit
I have bargained back and forth with him.
After all the back and forth he told me today his best deal is $8400 differance out the door.
I dont think im going to find a deal anywhere close to this.
What do you guys think?
/ Trade CK35 for a CK2610? #2
Seems likes a pretty good deal to me. The inter compatibility of the backhoe is nice. The cab would be nice option and well worth money in my opinion. The great thing about the ck2610, is it uses the same exact motor as the ck 35. But all in all thats not to bad priced especially when you consider the new subframe and cab has to be probably 3000-4000 of the price at least.
/ Trade CK35 for a CK2610? #3
Ijust traded a 2014 ck2510hst w/ 220 hrs on a new Ck2610hst /Fel, Loaded ag tires, 2 sets of rear remotes and weld on bucket hooks. They gave me 14,000 for my trade and I had to buck up $3589 ish which included Pa sales tax. Price on my machine was $17,378 before trade and sales tax. I did get the $150 firefighter rebate in the mix. Bought mine at Hess farm equipment in Canton, pa. Ask for Kevin.
/ Trade CK35 for a CK2610? #4
Oops.... Sorry read right past the part about the backhoe. 8k sounded high for just a FEL??
/ Trade CK35 for a CK2610? #5
Price sounds reasonable. But I'm wondering what your uses are for it because of the difference in hp. That's a substantial difference.
I use it for spreading gravel on my road, plowing snow and the backhoe for cleaning out the pond and some misc digging. I was told from a few different dealers, for I what I do with the machine, I'll never notice the difference in HP. I'm told the only time I would notice a difference would be if I was using ground engagement equip for farming.
@tiogajoe Im also getting the hard field cab with heat, lights, front wiper and cab sound dampening accessory. Also a new sub frame for my existing BH
The field cab is something like $5000 and the subframe is is $600.
So the deal without the cab and subframe would have been $2400 out the door.
I know Im going to love the hard cab.
/ Trade CK35 for a CK2610? #7
Yes that sounds logical to me as well. I would think the extra horsepower would not be missed unless you are running a tiller snowblower bush hog or something like that off the PTO. And I love my hard cab is been a great addition. Let us know how you like it
/ Trade CK35 for a CK2610? #8
Why do the deal at all? Doesn't the CK35 do everything you need? On resale, many users will want that extra HP you are giving up.
/ Trade CK35 for a CK2610? #9
... clearly he wants the comforts of the factory cab is why he is considering trading. Life's too short to be uncomfortable.
/ Trade CK35 for a CK2610? #10
Not really that clear. At least not to me. Anyway, they make a dealer-installed hard cab with heat,AC, wiper, etc for the CK35. FWIR, it's pretty nice...if still available.
/ Trade CK35 for a CK2610? #11
I don't understand either... your CK is just being broken in. No way I'd do that, and especially not for $8k outta pocket!
/ Trade CK35 for a CK2610? #12
I'm partial since I own one, (so does the op).
I would keep the CK35. Heated cab is nice in the winter, but what about the summer? does it have ac? $8000 for a cab on a smaller tractor with less power and without all the standard options that came with the CK series, now a la crate on the CK10 series, makes no sense to me. JMO
/ Trade CK35 for a CK2610? #14
I have the cozy cab and I love it. Has heat but no AC. Very strong and durable
/ Trade CK35 for a CK2610? #16
I don't think they make one for the CK10 series but I could be wrong.
/ Trade CK35 for a CK2610? #17
How does the backhoe work with a field cab installed? My dealer told me that once the field cab is installed, it's not practical (i.e. very expensive and time consuming) to remove it.
Also, how does the hydraulic flow of the CK2610 compare to your CK35 and to the backhoe requirements?
/ Trade CK35 for a CK2610? #18
How much was the cozy cab if you don't mind me asking?
I found mine on Craig's list but I think they range from 3-5000 new depending on how you option them up.
/ Trade CK35 for a CK2610? #19
No problem with the backhoe on mine I just have to keep the backhoe seat pulled forward. It touches the glass a little under a extra hard strain from flex in the sun frame. But has not been a problem yet.
The CK2610 has the same options that my CK35 has.
The backhoe goes on and off basically the same
The specs between the two are very close
My CK35 has been nothing but trouble, the main vertical support on the fel cracked in half, ignition switch went bad twice, tranny was leaking, etc. I know some have no issues but mine has been a money pit.
CK35 Specs
Hydraulic
Maximum Pump Flow 12.7 gpm (48.3 l/min.)
Operational
Lift Capacity 24 in. Aft of Hitch: 1,764 lbs. (800 kg)
PTO Horsepower 27.6 hp (20.6 kW) @ 540 rpm
Hitch Cat. I
Power Take-Off Live
Measurement
Length With Ag Tire & 3-point Hitch: 122.2 in. (3,103 mm)
Height From Top of ROPS: 96.8 in. (2,460 mm)
Width With Ag Tire: 54.6 in. (1,387 mm)
Weight With Ag Tire & ROPS: 3,151 lbs. (1,430 kg)
Wheelbase With Ag Tire: 66.1 in. (1,680 mm)
Turning Radius With Brake: 9.5 ft. (2.9 m)
Ground Clearance With Ag Tire: 13.82 in. (351 mm)
Engine
Engine Model 3A165LWM
Gross Horsepower 34 hp (25.4 kW) @ 2,600 rpm
Displacement 100.5 ci (1,647 cc)
Cylinders 3
Aspiration Natural
Fuel Type Diesel
Fuel Tank Capacity 7.9 gal. (30 l)
Drivetrain
Transmission Type Manual
Number of Speeds Forward & Reverse: 8
Tires Front Tread Ag: 43.5 in. (1,105 mm)
Rear Tread Ag: 38.2 - 51.3 in. (970 - 1,302 mm)
Brakes Wet disc
Speed - Forward 0.98 - 14.91 mph (1.57 - 24 km/h)
CK2610 Spec:
Operational
Lift Capacity 24 in. Aft of Hitch: 1,631 lbs. (740 kg)
PTO Horsepower 21.5 hp @ 540 rpm
Hitch Cat. 1
undefined
0 9204
1 13442
2 13685
3 13690
Measurement
Length With Ag Tire & 3-point Hitch: 120.9 in. (3,070 mm)
Height From Top of ROPS: 99.2 in. (2,520 mm)
Width With Ag Tire: 55.1 in. (1,400 mm)
Weight With Ag Tire: 2,701 lbs. (1,225 kg)
Wheelbase With Ag Tire: 65.7 in. (1,670 mm)
Turning Radius With Brake: 8 ft. (2.4 m)
Ground Clearance With Ag Tire: 13.4 in. (340 mm)
Engine
Engine Model 3A165LWM-U
Gross Horsepower 24.5 hp (18.2 kw) @ 2,600 rpm
Cylinders 3
Aspiration Natural
Fuel Type Diesel
Fuel Tank Capacity 9 gal. (34 l)
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
(2) 3"X24" HYD CYLINDERS (A60430)
(2) 3"X24" HYD...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2023 HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A60429)
2023 HANGCHA...
CASE 450CT SKID STEER (A60429)
CASE 450CT SKID...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
