Advice for external power for fueling system
   / Advice for external power for fueling system #11
I found a 250 gallon oil tank from a guy in town for free. Immaculate condition. Tonight I just picked up a rebuilt GPI pump (110vac and 30gpm) with a new hose and trigger nozzle. Now I just need to put it all together and get fuel delivered.
I知 quite pleased with the setup. It should make for pretty comfortable refueling at -20.
   / Advice for external power for fueling system #12
Sounds like the makings of a good setup. However - at those temps I think I'll remain inside and have a cup of hot cocoa. Believe me, retirement is a grand thing.
   / Advice for external power for fueling system #13
I tried using my tractor's battery as power to the 12V fuel transfer pump (I've got a 50ltr tank, pump & nozzle set up on a wheeled pallet). It worked using alligator clips but really became a bit of a pain in the arse.
I simply bought a small 12V marine type battery & mounted it on the fuel caddy. alligator clips onto the terminals when needed, off when not. Trickle charger every now and then when required.
Now with picture "goodness":
   / Advice for external power for fueling system #14
Hello
I am a new tractor owner [if you look closely at my profile photo, there isn't any dirt on my tires] and I am trying to create a small refueling system for my JD 4052R. I am considering using a 55 gal drum with a 12V transfer pump (like a GPI 8GPM or 12 GPM pump). These pumps draw 11 amps and 18 amps respectively.
I would like to run the pump off my tractors battery. The battery case is a bit difficulty to open and close so I would like to to somehow wire an exterior power plug to the battery or electrical system. The tractor comes with a power port but it is only rated to 10 amps.
Does anyone have any suggestions for this type of set up? Are there better DC electrical connectors to consider than the "cigarette lighter" type?
Is this a reasonable approach to refueling?
Thanks
If you are certain about using a 55g drum, then X2 on Anderson power connectors. I use them to power the fill-rite pump on my truck mounted diesel transfer tank.
I also store gas in a 55g drum with a crank pump for my house backup generator, and it is a royal pain to fill with cans.
   / Advice for external power for fueling system #15
Hello
Thanks
The difficulty opening up the hood to refuel made me look at just getting a small automotive battery and permanently attaching it to my Fillrite 15GPM pump. I hooked up a battery maintainer to it to keep it charged.
   / Advice for external power for fueling system #16
I use the Anderson plugs to power my fuel pump from the tractor. Works great.
Thanks to everyone for the terrific advice and information.
   / Advice for external power for fueling system #18
"Anderson Plugs" is the designator for several higher amperage modular plugs. I use SB175s for jumper cables, winch power & other things. Power Poles is the designator for the ones that support up to 45 amps. They are designed slightly differently but use the same genderless design with the self wiping & cleaning contacts.
   / Advice for external power for fueling system #19
Here is a neat transfer pump.
Cheap (like under $15.00) and efficient with a plus that it self drains back to the drum so no smelly spills.
Small Volume Oil Pump Water 12V 24V Diameter 38MM Wateoesel Aluminium Alloy Belt Filter Net Oil Suction-in Pumps from Home Improvement on Aliexpress.com | Alibaba Group
I have one and was very impressed with performance. You have to supply the output tube and I found that radiator hose works best.
Poly tubing simply gets too stiff with cold and as well I think fuel reacts to stiffen the poly.
The flow rate is impressive so keep your hands on the power switch.
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
Adams 8 Ton Weigh Hopper (A55301)
Adams 8 Ton Weigh...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
