Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,761
My blower is currently at a fabricator shop. Having 3" wings added to each side to increase my width out from the edge of the rear tires
   / Pictures of your snow weapons #3,762
That may be my next "addition". My front tires dig into the bank depending on the direction the road takes because the blower on the rear is close to the width of my rear tires. It's fine on the straights.
   / Pictures of your snow weapons #3,763
Blower is 68" wide, tires are at 66" width. Problem is my driveway has drop offs on the sides. 2 inches is a little too close for comfort.
   / Pictures of your snow weapons #3,764
That's a nice driveway. Is that a steel bridge? Or wood?
   / Pictures of your snow weapons #3,765
Wooden deck and rails. Built across 4 steel I beams of the same size used in freeway overpasses. Prepared reinforced concrete abutments
   / Pictures of your snow weapons #3,767
No reason why you could not add "wings" to your blower to artificially make it wider.
Dave M7040
Scroll up. Its at the fabricator's shop having 3" wings added to each side
   / Pictures of your snow weapons #3,768
Have posted this before, but this "wing" will get the snow off the road and into the ditch.. :D
   / Pictures of your snow weapons #3,770
Powerscol
Own design and had it fabricated. Will hang off the left or right FEL mounting stub, and pins to the drawbar with telescoping push arm, then is lifted using a chain around the 3 ph arm. Quick on and off, and works like a dream..
A google search for "wing plow beenthere" and some of the build in progress can be viewed.
For starters
http://www.tractorbynet.com/forums/john-deere-owning-operating/159770-wing-plow.html
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2016 Cat TL1055D Telehandler (A55314)
2016 Cat TL1055D...
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A55973)
2012 Chevrolet...
