   / Your last generator Maintenance Run #1,261
Did the batteries explode while on trickle, when attempting to start the engine or when the engine started and the alternator started charging the battery? Just because it was on a trickle charger, doesn't meant that's what blew up the battery. Unless the trickle charger destroyed the battery, but didn't initiate the explosion.
dont know, all i know is generac admitted the problem and changed their chargers. problem went away
g and bd - thanks for the feedback.
Rgds, D.
   / Your last generator Maintenance Run #1,263
how old were these generac units with bad chargers? Was it that they weren't "smart" and overcharged or simply
malfunctioned? Mine is three years old, makes me wonder.
We have lost power three times in the last week. Once for an hour and a half. First time it was right at freezing out and boy that Generac made some odd noises starting up. Seems to surge and run faster than it should, then it gets its brain on and settles down. Even with propane these gens don't like starting in the cold very much, and I hate the fact they run up to full speed so fast. I have 26 motors to maintain and I would never, ever ever run a cold engine up to full speed that fast, but that's the real world of generators. Block heaters have to be the way to go, even with full synthetic oil.
   / Your last generator Maintenance Run #1,264
That's ANOTHER reason I like to use my tractor for my whole house generator...
"I" control start up and what happens, and my tractor always starts and is ALWAYS ready to go, and with long oil change intervals too...
SR
You are probably doing it already d - if the battery is standard flooded lead-acid, I'd just keep a close eye on fluid levels. You'll see them dropping down fast, if the the charger is misbehaving.
If Generac didn't issue a recall, that's a bit surprising, for a company of that size.
Rgds, D.
   / Your last generator Maintenance Run #1,266
The big air cooled generacs take it immediately to 3600 rpm until it warms up.
Oh and the soft start that I linked to earlier are only for scroll compressors.
   / Your last generator Maintenance Run #1,268
they were of the 2008-2010 vintage that ive seen. anything after 2013 has the evolution controller. they never have issues that ive seen
   / Your last generator Maintenance Run #1,269
generac offers oil filter and battery heaters...and a breather tube heater for super cold climates. there about 80-90 each. worth their weight in gold.. i can tell the difference in how the generators sounds on cold day startups. the units sound way happier.
   / Your last generator Maintenance Run #1,270
Rgds, D.
i dont know if they ever actually issued a recall or not. that was before my time working on them. ive only witnessed a few myself. if the owners kept up the electrolyte levels there was no issue. heck, i even check mine yearly just to be sure.
i went 19 years having a manual start unit. i only switched out to the 22 kw fully automatic unit a little over a year ago. after two years of 3-5 days without power, enough was enough.
the new units power my entire house and the barn. the horse waterers wont freeze now. i put a portable interlock device on my shop cause i couldnt open my roll up door last time power failed. i have a few portable generators laying around.
when we had the 5 day outage, i loaned them out to neighbors. it still amazes me that most of my neighbors dont even have a 2000 watt gen available. all they like to do is sit in the dark i guess:cool2:
2011 Genie Z80 Man Lift (A54865)
2011 Genie Z80 Man...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
Toro Mower (A50324)
Toro Mower (A50324)
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2019 BOBCAT T590 SKID STEER (A52706)
2019 BOBCAT T590...
