Ruts in concrete on Interstate Highway
   / Ruts in concrete on Interstate Highway #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
I travel over Donner Summit (I-80) between Nevada and California pretty frequently.
This section was entirely refurbished a few years ago. I watched the concrete pour and it seemed like about 14 inches thick with lots of rebar. Now, a few years later, I am seeing ruts in the concrete in the truck lane.
The ruts are so bad I can't use that lane when towing a trailer. The trailer wheels are a little wider than my truck, so if truck wheels are tracking the ruts then the trailer is not-- making it wander around.
I don't ever remember seeing ruts in concrete. Is this possibly a bad mix of concrete that has caused this?
   / Ruts in concrete on Interstate Highway #2
Probably studded tires
   / Ruts in concrete on Interstate Highway #3
I agree must be studded tires. Concrete does not rut like asphalt.
   / Ruts in concrete on Interstate Highway #4
Also agree w/studded tires.
I89 Lebanon,NH. tar has the same results every now and than some loses control because of hydroplaning.
   / Ruts in concrete on Interstate Highway #5
I never heard of ruts in concrete, but then I've never used studded tires either.
   / Ruts in concrete on Interstate Highway #6
I think that chain use on the semi truck & trailers has become more common these days, even on the trailers.
   / Ruts in concrete on Interstate Highway #8
It seems to me that some of the worst vehicle destroying roads I have driven were concrete. I'm guessing that concrete roads are much more difficult and expensive to repair.
   / Ruts in concrete on Interstate Highway #9
Here in snowy Quebec we must install (by law) winter tires after Dec 15 subject to fines.
If you are going south for the winter a special permit can be obtained to exempt the snow tire ruling and is valid for only 10 days.
All seasons no longer allowed.
Studded tires only permitted on vehicles under 3000 lbs with fines if caught over 3 k lbs.
With 2 sets of tires and dual changeovers it gets costly. Typically the charge is $10.00 per tire X 4 twice yearly.
Latest is to also charge to store your off season tire set!
As I keep my vehicle for generally 10 years I invest in steel rims to mount the winter snows and a good jack and impact nut driver.
   / Ruts in concrete on Interstate Highway #10
Long, long ago, when I was working on my Civil Engineering degree, the "Concrete Institute" advertised "concrete for permanence" in highway surface construction.
In a cold climate. concrete is the very worst on grade highway surface, but for most bridges, and overpasses, it is absolutely necessary.
HARDEE 16' T/A TILT TOP TRAILER (A58374)
HARDEE 16' T/A...
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2014 VOLVO VNL DAYCAB (A58214)
2014 VOLVO VNL...
