How Do I Repair A Broken Granite Post
   / How Do I Repair A Broken Granite Post #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
I bought a nice granite post for a sign on my property, and I broke it. It’s 6 inch x 6 inch x 9 foot and I broke it in two pieces about 4 ft x 5 ft. I did mount the bottom 4 footer in the hole and compacted it with gravel. I’d like to place the top on that, cemented, and have it hold a small sign. I dont think regular mortar will work, so I am looking for some sort of epoxy. Anybody have experience with this?
   / How Do I Repair A Broken Granite Post #2
You might have to drill a hole into both pieces and use a piece of rebar as a type of dowel to keep it together and strong enough to hold a sign without breaking at the joint. Epoxy both holes and the faces of the break, slip the rebar into the part that is in the ground and slide the top 5' piece over the rebar. Just a couple of inches into each piece should do the trick.
   / How Do I Repair A Broken Granite Post #3
Basically, you don't.
Only way to do it where it will survive our winters is to drill both sides for rebar and epoxy. I've twice tried to drill those holes with a sds hammer and both times cracked the post.
A water jet or fancy diamond mill maybe?
My advice; find another post and don't break this one :D.
   / How Do I Repair A Broken Granite Post #4
How about a fancy metal sleeve to go on the outside of the post to hold the two pieces together? You could have one to compliment the sign. Could be made from wrought iron or many other designs.
   / How Do I Repair A Broken Granite Post #5
Yep a chemical fix just isn’t. Rebar and a drill is the way to go. With the rebar you can use epoxy or mortar- it really won’t matter.
   / How Do I Repair A Broken Granite Post #6
Maybe four clearance holes in from the corner drilled w/ diamond stone cutting bit. A two part epoxy filling the holes and the fracture surface. Assuming the surfaces still mate well it might look good as new from a short distance. Otherwise maybe you could fabricate some long flat metal splices that have structural pins with decorative heads that go into holes drilled on the sides of the posts.
   / How Do I Repair A Broken Granite Post #7
Need to rent a Hilt hammer drill. I would drill as deep of hole as possible. Both top and bottom pieces. Gorilla glue works on stone. Glue the top piece first filling the hole with glue and inserting the rebar. This is done inside with the post upside down. Get a large folding ladder, Level, and C clamp to go outside. Fill your lower hole with gorilla glue and coat the flat broken pieces on both ends. With help slip the rebar into the bottom hole. Use the ladder to clamp the top to a ladder leg with the C clamp. Plenty of set time so make it pleasing to the eye. Leave it set for a couple of days. Pre drill any holes needed for sign inside.
   / How Do I Repair A Broken Granite Post #8
Okay maybe too nerdy here but...
In this case with heavy stone, gravity is your friend. Clamps are nice and useful but understand that adhesives tend to shrink (exothermic process) so unless your clamps are spring loaded, you will loose clamping force and potentially introduce micro voids in your bond line. I would bond this in the upright position to take advantage of the natural pressure. Also, make sure your bonding surfaces are clean. Good luck.
   / How Do I Repair A Broken Granite Post #9
I really like this idea. :thumbsup: Perhaps presenting your problem to a local 'artisan' for their ideas. Because it would be a unique 'fix' the sleeve maker would reduce the price if they're allowed to use it for future advertising of their craft. A fancy band would cover up whatever method you use to re-bond the two pieces.
This is (somewhat) similar to a problem that I had with my actual double 'french doors' (individual panes of glass)... over years of time they'd expanded and would no longer close. A carpenter who specialised in these doors recommended all new doors. I suggested to save the existing doors and install metal brackets, inside & out, to brace the doors. The carpenter hadn't thought of that ('blinkers on').
Anyway, he got a local metal shop to make up the bands/brackets and 'saved' the existing doors. He now has something else to offer to future customers in a similar situation.
I'll upload some pictures of the doors if I can get my computer to cooperate. :pullinghair:
   / How Do I Repair A Broken Granite Post #10
Com'n Wag! You know what we say, "no pics, it didn't ......" :D
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
