Trying to find a new OOS 70hp tractor with a power shift is impossible.
   / Trying to find a new OOS 70hp tractor with a power shift is impossible. #1
Risefarm
Burringbar, NSW
JD 5720, Yanmar 3100, Fiat 70ci Ag Crawler,
Hi All
I am interested if any one knows of a new OOS (Open Operator Station) tractor ie no cab, around 70hp WITH a power shift transmission. Plenty have power forward reverse shuttle but no manufacturers have clutch less power shift transmissions around 70 HP in an OOS that I have been able to find. Our farm is all hills and we need clutchless gear shifting. I currently have a JD5720 with 4 speed power shift but it has a cab and I need to start to use a herbicide spray gun from the seat so a cab is not the go.
   / Trying to find a new OOS 70hp tractor with a power shift is impossible. #2
Closest I think I could recommend would be a large Deere 4 series 4066 with hydrostatic transmission
Brett
Hi Brett
Thanks but the tractor needs to be a loader tractor able to easily lift one tonne fert bags. The 4066 doesn't quit get there for me and hydrostatic is not really somewhere I would go.
   / Trying to find a new OOS 70hp tractor with a power shift is impossible. #4
Hi Brett. Welcome to the forum!
:tractor: I'm going to move this thread over to our buying, pricing, and comparisons section to see if we can come up with a few more suggestions.
   / Trying to find a new OOS 70hp tractor with a power shift is impossible. #5
Have you considered some of the CVT models, or the AGCO's Valtra and Fendt
   / Trying to find a new OOS 70hp tractor with a power shift is impossible. #6
Have you checked out the new Yanmar YT359 with the Integrated Hydro Mechanical Transmission? It's clutchless and more efficient than an HST, but only 59hp.
   / Trying to find a new OOS 70hp tractor with a power shift is impossible. #7
Smallest Deere 6R should still have the powerquad? (4-speed powershift x 4 or 6 ranges)
Don't think there has been a FULL powershift tractor under 100 PTO since the Ford select-o-speeds Lots of partial range powershifts 60 to 100 PTO HP.
You are in AU? likely different models there which makes things harder.
   / Trying to find a new OOS 70hp tractor with a power shift is impossible. #8
I'd be looking at the Vario mentioned above...
SR
Smallest 6R is about 100hp from memory, its too big. Not looking for a full powershift just need to change clutchless within a range. Even something with a high low range in a range is not available in an open station
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Butterfly Artwork (A55758)
Butterfly Artwork...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2006 APPA TL (A55787)
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
